Dual Want Policy Based Routing Problem
networksniffer
Hello!
I have configured 1700 series router to forward workstation traffic through one port and the voice through another. The Configuration is pretty straight forward, but we experience a major problems. When the SIP phones plugged in to the switch with pass through to the computers, we loose connections to PBX or Internet and it's not consistent, it's flapping in uneven amount of time. I can work all day and then just stop working with no clear cause. It does happened when only phones are connected to integrated switch alone. Completely makes no sense.
When this occurs i can go the router and can ping everhing but NAT translation is just stop working, which is the reson to lost connections.
here is the config:
hostname cartergeer
boot-start-marker
warm-reboot
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool PC-SUBNET
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 7.228.35.42 7.228.37.195 8.8.8.8
   domain-name greatbasin.net
   default-router 192.168.1.1
ip domain name greatbasin.net
ip name-server 7.228.35.42
ip name-server 7.228.37.195
ip name-server 8.8.8.8
archive
log config
  hidekeys
interface FastEthernet0
description WAN1
ip address 7.228.13.165 255.255.255.252
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet1
decription WAN2
ip address 7.228.13.169 255.255.255.252
ip nat outside
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description LOCAL-LAN
ip address 192.168.2.1 255.255.255.0 secondary
ip nat inside
ip policy route-map LAN-TO-WAN
interface Async1
no ip address
encapsulation slip
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 0.0.0.0 0.0.0.0 FastEthernet1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
ip nat inside source list 102 interface FastEthernet1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
route-map LAN-TO-WAN permit 10
description PC-SUBNET-NAT
match ip address 101
set interface FastEthernet0
route-map LAN-TO-WAN permit 20
description VOICE-SUBNET-NAT
match ip address 102
set interface FastEthernet1
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
end
cadet alain
You should modify your config like this:
no ip nat inside source list 101 interface FastEthernet0 overload
no ip nat inside source list 102 interface FastEthernet1 overload
no route-map LAN-TO-WAN
set ip next-hop x.x.x.x
set ip next-hop y.y.y.y
route-map NAT-To-WAN1
match interface f0
route-map NAT-To-WAN2
match interface f1
ip nat inside source route-map NAT-To-WAN1 interface FastEthernet0 overload
ip nat inside sourceroute-map NAT-To-WAN2  interface FastEthernet1 overload
Alain
Cadet first of all thank you for your response and work! =) I did made  the changes that you proposed and applied them today and I will test  them for the few days and will report back. But, what is the difference  in my approach vs yours for the NAT?
