Dude with configuration of GRE
paloma_sentos
Hello!, I'm forming a GRE to handle IPX
into VPN. My interface serial 2 is connected to V.35 cable and the other point is db60 and it is connected to modem.
My server requires other applications from my local network. My gre configuration is:
int tunnel 0
ip add ip_address
tunnel source f0/0
tunnel destination ip_address
ip tcp adjust-mss 1436
keepalive 5 4
My question is I must to connect the fast of my router inside the fast of my server for configure my gre? or I can to connect my S0/2 like tunnel source s0/2?
paolo bevilacqua
Hola,
As tunnel source you should use an interface which address is reachable and pingable from the other router. If both serial and FE are, both will work.
