Dumb device can't talk over MULTILINK PPP WAN link
ppauly
I've got several remote locations with Verifone credit card machines (network based, not serial). When my links are setup like this, the machines work fine:
interface GigabitEthernet0/0.1
encapsulation dot1Q 123
ip address 10.1.xx.xx 255.255.255.0
ip helper-address 10.1.xx.xx
interface GigabitEthernet0/0.2
encapsulation dot1Q 223
ip address 10.2.xx.xx 255.255.255.0
ip access-group 121 in
interface GigabitEthernet0/0.3
encapsulation dot1Q 323
ip address 10.3.xx.xx 255.255.255.0
ip pim sparse-mode
interface GigabitEthernet0/0.4
encapsulation dot1Q 423
ip address 10.4.xx.xx 255.255.255.0
ip access-group 120 in
interface GigabitEthernet0/1
ip address dhcp
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/1/0
ip unnumbered GigabitEthernet0/0.1
ip pim sparse-mode
service-policy output Serial-Policy
load-interval 30
interface Serial0/2/0
ip pim sparse-mode
load-interval 30
Everyone I've talked to says I should be using multilink PPP, but when I do, the credit card machine can't connect out through the WAN. Every other device works fine, PC's, IP Phones, etc. Just not the credit card machine. Here is the config with PPP:
interface Multilink 1
ip pim sparse-mode
ppp multilink
ppp multilink group 1
ip pim sparse-mode
ip address dhcp
shutdown
duplex auto
speed auto
media-type rj45
no ip address
encapsulation ppp
ppp multilink
no ip address
encapsulation ppp
ppp multilink
Again, every other device works fine, just not the credit card machine. I had to switch the config back and the CC machine started working again. I control both sides of the WAN link. I've tried "ppp multilink fragment disable" and that didn't help. Should I be using a loopback interface for the common IP address? Any ideas or suggestions?
6 Replies 6
If enabling multilink breaks connectivity for one application it sounds like a possible MTU issue. Try lowering the MTU to 1450 on the interface or use 'ip tcp adjust-mss 1450' if it's a TCP application and see if that helps.
Sundar
Which interface, the multilink or the serial interfaces?
It shouldn't matter but try it on the multilink interface.
I tried setting the MTU on the interface as well as doing ip tcp mss 1450 and neither helped the situation.
You may have to run some debugs to see why the traffic fails. You may be able to find something with debug ppp multilink data or events. As with any debugs, exercise caution and run the debugs during during a maintenance window.
Sundar
avmabe
Level 3
Level 3
Please see this link and turn on transparent bridging... I have used this in the past to solve these issues specifically!
http://www.cisco.com/en/US/tech/tk331/tk660/technologies_tech_note09186a0080094471.shtml
Let me know if this works.
