DUPADDR problem on the same interface
robertreymund
Hello everybody!
I'm trying to configure my network like this:
ISP – (VDSL) Router from ISP in bridge mode – Cisco 876 FastEthernet 3 with VLAN4
This means the VLAN4 will be my WAN interface. VLAN1, 2 and 3 are connected to the internet through VLAN4.
My Problem: The internet is working fine, but after 2-5 minutes I have the following error in the log:
000045: *Jul 23 13:33:12.003 PCTime: %IP-4-DUPADDR: Duplicate address 178.195.XX.XX on Vlan4, sourced by 98d6.bb71.35f1
So I checked the mac-addresses:
routerHome#sh mac-address-table vlan 4
Destination Address  Address Type  VLAN  Destination Port
0004.201e.dac6          Dynamic       4     FastEthernet3
001f.9e66.1804          Self          4     Vlan4
0024.932b.1940          Dynamic       4     FastEthernet3
0090.d063.ff00          Dynamic       4     FastEthernet3
0090.d063.ff04          Dynamic       4     FastEthernet3
78d6.f093.ad17          Dynamic       4     FastEthernet3
98d6.bb71.35f1          Dynamic       4     FastEthernet3
routerHome#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  178.195.XX.1            1   0090.d063.ff04  ARPA   Vlan4
Internet  178.195.XX.XX           -   001f.9e66.1804  ARPA   Vlan4
Why does the VLAN4 has problems with one of his own mac addresses?
You’ll find my configuration and many other interesting logs in the file “problemdubmac_techsupport.txt”
this is a duplicate
by the way the answer is the same... before issuing show ip arp or show arp you should issu a broadcast :
ping 255.255.255.255
and then issuing again the show arp
Alessio
Thank you for your answer. Here is the output:
routerHome#ping 255.255.255.255
Sending 5, 100-byte ICMP Echos to 255.255.255.255, timeout is 2 seconds:
routerHome#sh arp
Internet  192.168.1.1             -   001f.9e66.1804  ARPA   Vlan1
Internet  192.168.1.33            0   f0de.f180.3539  ARPA   Vlan1
Internet  192.168.1.81            0   f0de.f180.3539  ARPA   Vlan1
Internet  192.168.2.1             -   001f.9e66.1804  ARPA   Vlan2
Internet  192.168.3.1             -   001f.9e66.1804  ARPA   Vlan3
How can I prevent this dublicate address problem?
paolo bevilacqua
Seems to me the duplicate is some other customer on the same subnet, thing about which you can't do anything.
Complain to ISP and try get him shut down, or your address changed.
