Dynamic DNS not updating - Cisco Router 2901
Deepak Kumar
Hi All,
I configured DDNS on cisco router with NO-IP services but it is not updating and there is no any debug out showing.
My configuration as below:
ip name-server 213.42.20.20
ip name-server 195.229.241.222
ip ddns update method no-ip
HTTP
add http://xxxx@xxxxx.com:xxxxxxx@dynupdate.no-ip.com/nic/updatehostname=<h>&myip=<a>.
interval maximum 2 0 0 0
interval minimum 0 6 0 0
ip ddns update hostname xxxxx.ddns.net
ip ddns update no-ip
Please guide and share if any command is missing or any command for forcefully update the DDNS.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
nspasov
Hello Deepak-
It has been a while since I had to do this but I also recall having problems with ddns. As a result, I used IP SLA and it worked great. Have a look at the following link:
http://www.blindhog.net/cisco-routers-and-dynamic-dns/
I hope this helps!
Thank you for rating helpful posts!
Deepak Kumar
I found that configuration is correct but it needs to reboot device once after configuring DDNS on the cisco router. I rebooted the router and it is working fine.
Deepak Kumar
Deepak Kumar,
Glad you were able to solve your own issue! Also, thank you for taking the time to come back and post the solution here (+5 from me).
Now, since your issue is resolved, you should mark the thread as "answered" ;)
