Dynamic GRE Tunnel Setup
tigerpaws
Frequent Visitor
Frequent Visitor
I have a question on dynamic GRE Tunnel Setup that I hope someone can help.  The issue is in my tunnel setup, I need the local tunnel's destination on R1 to be whatever IP address that the remote tunnel's source on R4 acquires from its IP DHCP assignment.  Refer to the diagram below:
NSC-BR1-NA01-RIDR-Diagram.PNGWhen I configure R1's tunnel destination to be the known IP address assigned to the e0/1 of R4, I can ping R4 Loopback IP address as well as the remote Tunnel's IP address without any issue.  My question is if the remote tunnel's source on R4 acquires its IP address from DHCP, is there a way to configure the local tunnel's destination to be that DHCP IP address without knowing it in advance?
Below are the routers' configurations along with the outputs of show commands:
+ R1
hostname R1
interface Loopback0
 ip address 10.209.147.100 255.255.255.255
 ip ospf network point-to-point
 ip ospf 1 area 0
interface Tunnel208
 description GRE Tunnel between R1 & R4
 ip address 10.209.139.206 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip mtu 1372
 ip pim dense-mode
 ip tcp adjust-mss 1332
 ip ospf 1 area 0
 tunnel source Ethernet1/1
 tunnel destination 172.16.2.3
interface Ethernet1/1
 description WAN Connection
 ip address 192.168.6.2 255.255.255.252
 no ip redirects
 no ip proxy-arp
router ospf 1
 router-id 10.209.147.100
 log-adjacency-changes detail
ip route 0.0.0.0 0.0.0.0 192.168.6.1
R1#
+ R2
hostname R2
interface Ethernet0/0
 description "Link to R1"
 ip address 192.168.6.1 255.255.255.252
 no ip redirects
 no ip proxy-arp
 description "Link to R3"
 ip address 172.16.1.1 255.255.255.0
ip route 172.16.2.0 255.255.255.0 172.16.1.2
ip route 192.168.6.0 255.255.255.252 192.168.6.2
R2#
+ R3
hostname R3
no ip dhcp conflict logging
ip dhcp excluded-address 172.16.2.1 172.16.2.2
ip dhcp pool R4
 network 172.16.2.0 255.255.255.0
 default-router 172.16.2.2
 lease 7
 description "Link to R4"
 ip address 172.16.2.1 255.255.255.0
 description "Link to R2"
 ip address 172.16.1.2 255.255.255.0
ip route 192.168.6.0 255.255.255.252 172.16.1.1
R3#
+ R4
hostname R4
interface Loopback0
 ip address 10.209.147.11 255.255.255.255
 ip ospf 1 area 0
interface Tunnel208
 description GRE Tunnel Between R4 & R1
 ip address 10.209.139.205 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip mtu 1372
 ip pim dense-mode
 ip ospf 1 area 0
 tunnel source Ethernet0/1
 tunnel destination 192.168.6.2
 tunnel key 208
interface Ethernet0/1
 ip address dhcp
 no ip redirects
 no ip proxy-arp
router ospf 1
 router-id 10.209.147.11
ip route 0.0.0.0 0.0.0.0 Ethernet0/1
R4#
* R1
R1#sho ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Ethernet1/1                192.168.6.2     YES manual up                    up
Loopback0                  10.209.147.100  YES manual up                    up
Tunnel208                  10.209.139.206  YES manual up                    up
R1#sho int tunnel 208
Tunnel208 is up, line protocol is up
  Hardware is Tunnel
  Description: GRE Tunnel between R1 & R4
  Internet address is 10.209.139.206/30
  MTU 17912 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 192.168.6.2 (Ethernet1/1), destination 172.16.2.3
   Tunnel Subblocks:
      src-track:
         Tunnel208 source tracking subblock associated with Ethernet1/1
          Set of tunnels with source Ethernet1/1, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key 0xD0, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1472 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:01, output 00:00:01, output hang never
  Last clearing of "show interface" counters 04:28:41
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     533 packets input, 55734 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     543 packets output, 56634 bytes, 0 underruns
     0 unknown protocol drops
R1#sho ip route
Gateway of last resort is 192.168.6.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.6.1
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.209.139.204/30 is directly connected, Tunnel208
L        10.209.139.206/32 is directly connected, Tunnel208
O        10.209.147.11/32 [110/1001] via 10.209.139.205, 00:16:09, Tunnel208
C        10.209.147.100/32 is directly connected, Loopback0
      192.168.6.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.6.0/30 is directly connected, Ethernet1/1
L        192.168.6.2/32 is directly connected, Ethernet1/1
R1#sho ip ospf neigh
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.209.147.11     0   FULL/  -        00:00:36    10.209.139.205  Tunnel208
R1#ping 10.209.147.11
Sending 5, 100-byte ICMP Echos to 10.209.147.11, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/7 ms
R3#sho ip dhcp bind
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
172.16.2.3          0063.6973.636f.2d61.    May 14 2018 06:06 PM    Automatic
                    6162.622e.6363.3030.
                    2e30.3131.302d.4574.
                    302f.31
R4#sho ip int bri
Ethernet0/1                172.16.2.3      YES DHCP   up                    up
Loopback0                  10.209.147.11   YES manual up                    up
Tunnel208                  10.209.139.205  YES manual up                    up
R4#sho interfaces tunnel 208
  Hardware is Tunnel
  Description: GRE Tunnel Between R4 & R1
  Internet address is 10.209.139.205/30
  Keepalive not set
  Tunnel source 172.16.2.3 (Ethernet0/1), destination 192.168.6.2
   Tunnel Subblocks:
      src-track:
         Tunnel208 source tracking subblock associated with Ethernet0/1
          Set of tunnels with source Ethernet0/1, 1 member (includes iterators), on interface <OK>
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 04:17:11
     561 packets input, 58620 bytes, 0 no buffer
     1852 packets output, 162466 bytes, 0 underruns
R4#sho ip ospf neigh
10.209.147.100    0   FULL/  -        00:00:32    10.209.139.206  Tunnel208
R4#sho ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Ethernet0/1
L        10.209.139.205/32 is directly connected, Tunnel208
C        10.209.147.11/32 is directly connected, Loopback0
O        10.209.147.100/32 [110/1001] via 10.209.139.206, 00:18:39, Tunnel208
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.2.0/24 is directly connected, Ethernet0/1
L        172.16.2.3/32 is directly connected, Ethernet0/1
R4#ping 10.209.147.11
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/5 ms
0 Replies 0
