Dynamic OSPF cost on GRE interface?
daniel-nilsson
Is there any way to have dynamic ospf cost on an GRE interface insted of static (ip ospf cost 1234)
It would be nice to have the ability to have the GRE tunnel to inherit the actual cost of the path to the tunnel destination.
Type , if the cost is 35 to tunnel destination in the global routingtable (if the tunnel use global routing) for the primary path over the network, the cost would be 35 for the GRE interface, but if there is a failure in the network so the GRE needs to take an other path, the new path may be over small links and it would be to slow performance for the traffic that use the GRE interface. Lets say that the new actual cost to the GRE tunnel desinatin is 10000, it would be nice to have that cost dynamicaly inherit to the GRE tunnel cost what now would be 10000 insted of the old 35 and traffic that uses the GRE tunnel now can use an outher path with lower cost.
Many thanks
/Daniel Nilsson
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The only Cisco techonology that I'm aware of that might effectively provide results similar to what you desire, would be OER/PfR with PIRO (NB: don't know if it supports GRE tunnels).
Joseph W. Doherty
Disclaimer
Posting
ok, thanks I'll check it out.
