Dynamic routing by monitoring specific IP
andrew_ho
Please see diagram attached. Provided router C is the only router can be configured, is there any way for Router C to monitor the reachability of Router A, and then dynamically stopping redistributing the static route into OSPF, or changing the redistribution metric.
Andrew
rahulcapable
Hello Andrew,
What we can do is that we can track the reachability of router A IP address and configure in a way so tht static route will be there only till we have reachability to router A other wise static route will go down and hence will not be redistributed. For this to work router A Ip should be pingable from router C. Below is the config :
Make sure you remove the route ip route 10.0.0.0 255.255.255.0 10.2.2.1 before u add the below config
___________________________________
track 100 rtr 100 reachability
ip route 10.0.0.0 255.255.255.0 10.2.2.1 track 100
ip sla monitor responder
ip sla monitor 100
icmp-echo 10.1.1.1 source-ip 10.2.2.2
frequency 5
ip sla schedule 100 life forever start-time now
______________________________________
Will try this out, thanks.
Andrew
