dynamically routed private line, and statically routed IPsec tunnel
wfqk
Level 5
Level 5
Hi Anyone can explain the below two ways to connect two office? Thank you
First is "dynamically routed private line". Second is "statically routed IPsec tunnel"
The two names look a little weird. People usually do not mention it like this.
does this refer to the CCDA question below ?
Dynamically routed probably means that a dynamic routing protocol (EIGRP/OSPF) is used as opposed to static routes. Statically routed: the VPN tunnel is set up with static routes...
https://ciscoexam.online/CCDA/200-310/329
Yes It's. It should use "routing" instead of "routed" Thanks
