E1 is not working in ASR 920 Router by using VLL line from ISP.
we are using ASR 920 Router to connect two branch and ISP give us VLL (virtual leased line). We connected this two (Branch) router with VLL we can telnet and ping this router (Connectivity is OK)  but E1 is not working on both the router.
I will share below configuration for Branch 1 and Branch 2. Please if any one can assist in this.
Branch1 Configuration:
Branch1#sh run
Building configuration...
Current configuration : 3735 bytes
! Last configuration change at 03:32:51 UTC Sun Jun 13 2021
version 16.8
no service pad
no platform punt-keepalive disable-kernel-core
platform bfd-debug-trace 1
platform xconnect load-balance-hash-algo mac-ip-instanceid
platform tcam-parity-error enable
platform tcam-threshold alarm-frequency 1
hostname Riyadh_VLL
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
no logging console
enable secret 5 $1$.C7M$yS/ua/qS8E2r5STOCpVbo1
no aaa new-model
no ip domain lookup
mpls label protocol ldp
license udi pid ASR-920-12SZ-IM
license boot level advancedmetroipaccess
no license smart enable
spanning-tree mode pvst
sdm prefer default
diagnostic bootup level minimal
redundancy
controller E1 0/1/0
framing unframed
cem-group 0 unframed
controller E1 0/1/1
framing unframed
cem-group 1 unframed
controller E1 0/1/2
framing unframed
cem-group 2 unframed
controller E1 0/1/3
shutdown
controller E1 0/1/4
shutdown
controller E1 0/1/5
shutdown
controller E1 0/1/6
shutdown
controller E1 0/1/7
shutdown
transceiver type all
monitoring
cdp run
class cem mycemclass
payload-size 512
dejitter-buffer 10
idle-pattern 0x55
interface Loopback0
ip address 1.1.1.19 255.255.255.255
interface GigabitEthernet0/0/0
no ip address
media-type rj45
negotiation auto
mpls ip
service instance 1 ethernet
encapsulation dot1q 2251
rewrite egress tag push dot1q 2251
bridge-domain 2251
interface GigabitEthernet0/0/1
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/2
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/3
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/4
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/5
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/6
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/7
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/8
no ip address
negotiation auto
interface GigabitEthernet0/0/9
no ip address
negotiation auto
interface GigabitEthernet0/0/10
no ip address
negotiation auto
interface GigabitEthernet0/0/11
no ip address
negotiation auto
interface TenGigabitEthernet0/0/12
no ip address
interface TenGigabitEthernet0/0/13
no ip address
interface TenGigabitEthernet0/0/14
no ip address
interface TenGigabitEthernet0/0/15
no ip address
vrf forwarding Mgmt-intf
ip address 10.10.10.119 255.255.255.0
negotiation auto
interface CEM0/1/0
no ip address
cem 0
xconnect 1.1.1.18 118 encapsulation mpls
cem class mycemclass
interface CEM0/1/1
no ip address
cem 1
xconnect 1.1.1.18 119 encapsulation mpls
interface CEM0/1/2
no ip address
cem 2
xconnect 1.1.1.18 120 encapsulation mpls
interface BDI2251
ip address 192.168.99.1 255.255.255.0
encapsulation dot1Q 2251
mpls ip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 1.1.1.18 255.255.255.255 192.168.99.2
mpls ldp router-id Loopback0 force
control-plane
Branch 2 Configuration:
Branch 2 #sh run
Current configuration : 3660 bytes
! Last configuration change at 23:04:28 UTC Sun Jun 13 2021
version 16.8
no service pad
hostname Test
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
enable secret 5 $1$fpPD$GhGSZceTcybW3vYcO8P22.
no aaa new-model
no ip domain lookup
license udi pid
sdm prefer default
redundancy
controller E1 0/1/0
framing unframed
controller E1 0/1/1
framing unframed
controller E1 0/1/2
framing unframed
controller E1 0/1/3
controller E1 0/1/4
controller E1 0/1/5
controller E1 0/1/6
controller E1 0/1/7
monitoring
cdp run
payload-size 512
dejitter-buffer 10
idle-pattern 0x55
interface Loopback0
ip address 1.1.1.18 255.255.255.255
no ip address
media-type rj45
negotiation auto
mpls ip
encapsulation dot1q 2476
rewrite egress tag push dot1q 2476
bridge-domain 2476
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
media-type rj45
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
no ip address
no ip address
no ip address
ip address 10.10.10.118 255.255.255.0
negotiation auto
interface CEM0/1/0
no ip address
cem 0
xconnect 1.1.1.19 118 encapsulation mpls
interface CEM0/1/1
no ip address
cem 1
xconnect 1.1.1.19 119 encapsulation mpls
interface CEM0/1/2
no ip address
cem 2
xconnect 1.1.1.19 120 encapsulation mpls
interface BDI2476
ip address 192.168.99.2 255.255.255.0
encapsulation dot1Q 2476
mpls ip
no ip http server
ip route 1.1.1.19 255.255.255.255 192.168.99.1
control-plane
so If any one can assist me.
Thanks.
9 Replies 9
Richard Burts
I do not have experience with this technology, and if someone who does have experience would jump into the discussion it would be good. But it looks to me like this is a "virtual" leased line and I suspect that you do not need the physical interfaces to make it work. The connectivity is supplied by the G0/0/0 interfaces and BDI. If you can ping and telnet between sites it looks to me like you should be good to go. Is there anything that is not working, other than the E1 interfaces?
Rick
Hi Richard,
Thanks for Support ,Yes only E1 is having issues.
Thanks.
Giuseppe Larosa
Hello @MustafaBinAmar0901 ,
it would be helpful if you :
a)  if you would use the same VLAN -ID on both branches.
I see two different VLAN-Ids used here Branch 1 VLAN 2251, Branch 2 uses VLAN 2476
Who performs VLAN ID rewrite ?   The PE Node ? But in this case the ISP must be aware of what you are doing.
b) you can run an OSPF process on the shared subnet 192.168.99.0/24 using it to publish the loopbacks.
At this point your circuit emulation configuration CEM may start to work as each of them can be compared to an EoMPLS pseudowires . These are point to point L2 services but LDP must run on the devices and an IGP as far as I know is needed.
Branch1 :
router ospf 10
network 192.168.99.0 0.0.0.255 area 0
network 1.1.1.1.19 0.0.0.0 area 0
Branch 2:
router ospf 10
network 1.1.1.1.18 0.0.0.0 area 0
When you define the pseudowire you need to point to the remote loopback IP address and to use a shared VC label for each of them.
Check with show mpls forwarding 1.1.1.18   on Branch1 the correct action is POP TaG = implicit null
on Branch 2 show mpls forwarding 1.1.1.19 should show the same POP TAG
The local E1 interfaces need to be connected to real E1 circuits to work.
Start by enabling OSPF and checking LDP .
Hope to help
Giuseppe
Thanks for support. Actually ISP provided that VLAN number, If we change that VLAN then Pinging Both Branch router Stop.
Regarding IGP before I configure OSPF as you told but we have same issues. See the above configuration is working fine if we use VPLS line from ISP. We check that, But for in VLL line, E1 is not working and in this two Branchs (Connectivity is ok but E1 is not working).
and see the output of command as you mention above.
Branch 1#sh mpls forwarding 1.1.1.18
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
19 No Label 1.1.1.18/32 0 BD2251 192.168.99.2
Branch2#sh mpls forwarding 1.1.1.19
19 No Label 1.1.1.19/32 0 BD2476 192.168.99.1
Please find the below attached output for Both Branch's.
Please advise
Thanks.
I had thought of it later after my first post.
Either there is MTU issue with VLL service or it drops MPLS frames.
Ask the ISP if you can send MPLS frames over the VLL service if the answer is no you have found the reason why the circuit emulation over MPLS is not working with VLL.
Hope to help
Giuseppe
Hi Giuseppe,
We ask ISP he is saying that he provided Layer 2 circuit. He is saying what every configuration we want to do we can do no issues.
Can you give me some more steps to check is there MTU issues or any other thing etc.
Thanks.
I check with ISP he is saying he give PLL line (no VLL). They are saying PLL layer 2 circuit.
Please advise if you can help me in this.
Thanks.
check with the new service PLL.
As a way to check an easier to troubleshoot service you can add a L3 MPLS VPN between Branch1 and Branch2 using dedicated loopbacks in VRF .
If this service will work , then the MPLS forwarding plane will be OK and you can move on checking the CEM over MPLS.
This is my suggestion because it is enough to use a ping test in vrf to check if the MPLS L3 VPN works. You need to add also MP BGP between the loopbacks of Branch1 and Branch2 in address-family vpnv4 and ipv4 vrf <name>.
Hope to help
Giuseppe
Hi Giuseppe,
I have little bit confused. I have access to only my two CISCO Router ASR 920 one is in Brach 1 and other is in Branch 2.
can you please share configuration as you will mention above.
Thanks.
