E1 line on cisco router
Just Kennie
Please I need some information about E1 line on a cisco router.
1. How does the interface for data look like.
2. Is it same as for voice.
3.Any special configuration on the router to bring the interface up, both for voice and for data.
Giuseppe Larosa
Hello Kennie,
a serial interface.
if controller e1 0/1/0 is configured for unframed
controller e1
channel-group 0 unframed
a serial interface is created se0/1/0:0
if you define timeslots
controller e1
channel-group 1 timeslots 1-15
channel-group 2 timeslots 16-30
two different serial interfaces are created
ser0/1/0:1
ser0/1/0:2
2) in voice the D channel is
ser0/1/0:15 so it is different and you see the single B channels in sh ip int brief
unless you use the more modern ds0-group command to create voice ports that are groups of B channels
T1 has D channel on 23th channel
3)
controller e1 0/1/0
no shut
if you are in a lab one side has to provide the clock to the other with
clock source internal
for voice additional commands may be needed depending on the scenario
Hope to help
Giuseppe
