E1 modul is not accesible
adriatikb
I have a 1721 router which have been used with another IOS then now. before repalcin the IOS E1 modul was fine .. could you help me
bellow you will find the show version
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(8)TPC10c, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(8)TPC10c, RELEASE SOFTWARE (fc1)
Router uptime is 2 hours, 1 minute
System returned to ROM by reload
System image file is "flash:c1700-y-mz.122-8.TPC10c.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memory.
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
Have you validated the IOS Support for E1 Modules before upgrading.
Do you want us to validate and provide the details or how ?
For a testing concern, can you down-grade to old version and to see if there are No Hardware Issue on the Router.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
guruprasadr
Level 7
Level 7
Pls Rate if HELPS
Best Regards,
Guru Prasad R
it was my fault the ios was wrong
i validated it with aditional E1 and everythink is ok.
best regards.
