Nat problem ?
EricSACSO
I have a problem with my NAT on a 2611xm router
After some time of use, I have no access outside from inside, the nat table (sh ip nat translation) is empty and appears no longer work, I do not understand what is happening!
The only solution is to reboot the router, once completed, everything is working properly.
Do you have an idea to help solve the problem?
Thx.
7 Replies 7
mounir.mohamed
Level 7
Level 7
Would you share your running configurations and show proc mem and show ver output.
My running config :
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname RTR-SAGES-001
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 errors
logging console critical
enable secret 5 *****
aaa new-model
aaa authentication login vpn_xauth_ml_1 group radius local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip source-route
no ip cef
ip tcp synwait-time 10
ip inspect audit-trail
ip inspect name INSPECT ...
audit-trail on
ip ips notify SDEE
no ip bootp server
ip ssh time-out 60
ip ssh authentication-retries 2
spanning-tree portfast bpduguard
username Admin privilege 15 secret 5 *****
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group VPN
key *****
dns 10.2.4.3
wins 10.2.4.3
domain vpn.priv
pool Pool_VPN
netmask 255.255.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map DYNMAP_1 1
set transform-set ESP-3DES-SHA
reverse-route
crypto map CMAP_1 client authentication list vpn_xauth_ml_1
crypto map CMAP_1 isakmp authorization list vpn_group_ml_1
crypto map CMAP_1 client configuration address respond
crypto map CMAP_1 65535 ipsec-isakmp dynamic DYNMAP_1
interface Null0
no ip unreachables
interface FastEthernet0/0
description Interface WAN
ip address A.B.C.D 255.255.255.248
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect INSPECT out
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
crypto map CMAP_1
interface FastEthernet0/1
description Interface LAN
ip address X.Y.Z.2 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect INSPECT in
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
router rip
version 2
network A.B.C.D
network X.Y.Z
ip local pool Pool_VPN 172.20.1.1 172.20.1.50
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip flow-export source FastEthernet0/1
ip flow-export version 5 origin-as
ip flow-export destination 192.168.99.101 2000
ip http server
ip http access-class 1
no ip http secure-server
ip nat translation timeout 300
ip nat translation tcp-timeout 30
ip nat translation pptp-timeout 65535
ip nat translation udp-timeout 30
ip nat translation finrst-timeout 30
ip nat translation dns-timeout 10
ip nat translation icmp-timeout 10
ip nat translation port-timeout tcp 21 3600
ip nat translation port-timeout tcp 20 3600
ip nat translation max-entries 65535
ip nat translation max-entries host X.Y.Z.40 2048
ip nat pool WEB X.Y.Z.80 X.Y.Z.90 netmask 255.255.255.0
ip nat inside source route-map RouteMAP_1 pool WEB overload
ip nat inside source static 172.18.171.34 X.Y.Z.40
logging trap errors
logging 192.168.99.101
access-list 100 remark ACL NAT - Route-MAP 1
access-list 101 remark ACL Outside
access-list 102 remark ACL inside
access-list 103 remark VTY Access-class list
snmp-server community **** RO
snmp-server enable traps ....
snmp-server enable traps rtr
no cdp run
route-map RouteMAP_1 permit 1
match ip address 100
Sh proc mem :
Processor Pool Total: 112400808 Used: 17107724 Free: 95293084
I/O Pool Total: 8388608 Used: 2043936 Free: 6344672
SH VER :
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version 12.4(5), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 31-Oct-05 20:06 by alnguyen
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
RTR-SAGES-001 uptime is 8 hours, 29 minutes
System returned to ROM by reload
System image file is "flash:c2600-advsecurityk9-mz.124-5.bin"
Cisco 2611XM (MPC860P) processor (revision 4.1) with 253952K/8192K bytes of memory.
Processor board ID *
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Thx for help !
Actually i was suggest it's memroy issue but it's not, there is enough memory.
So in order to islate the probelm let's trun off the IP nat Translation time-out command and check how the life gone be, if this doesn't work i think we gone use some Ipsec debug commands, but let's try the NAT time-out first.
You May accept or ignore my idea, i'm just trying to isolate the problem with you.
Thx for your help,
I will try to turn off timeout command and we will see what happens !
The crash does not happen immediately, but after several days of use! What complicates the matter further ...
Ok, keep it under monitoring and feed us back.
