E1 PRI and codecs
emadehsan
Hi Guys
here is my diagram
PBX--E1---Router1---E1---Router2--E1-PBX
I set codec G729 for pbx calls to user more bandwidth.
so should I do any configuration for passing this coded between R1 and R2?
or the router r1 acts with them as data?
1lumkk
You can set G729 as the preference on the dialpeer. For example.
dial-peer voice 11 voip
description #To R1#
destination-pattern 1....
session target ipv4:1.2.8.8
dtmf-relay h245-alphanumeric
codec g729ulaw
