e1 pri card to create diff channels
dear all below given is my router sh version.
------------------ show version ------------------
Cisco IOS Software, C2600 Software (C2600-IPBASE-M), Version 12.4(10a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 11-Oct-06 18:15 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Ghubra-Router uptime is 0 minutes
System image file is "flash:c2600-ipbase-mz.124-10a.bin"
Cisco 2611XM (MPC860P) processor (revision 4.1) with 127308K/3764K bytes of memory.
Processor board ID FCZ104472KN
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
will this router work with 1 port e1 card female serial type ,i dont have the part no of the card, im planning buy one.
my requirement is to buy the card where i can make 30 diff channels.
VWIC-2MFT and VWIC2-2MFT 2nd gen cards wont allow to create more than 2 channels.if u know the part no of the card pls share it.
Binoy.
carenas123
Level 5
Level 5
Yes, it will work and also please don't forget to update your IOS
