10-14-2009 07:50 AM - edited 03-04-2019 06:22 AM
Hi everybody,
I am working in a upgrade to IOS XR (Version 3.6.2) in a 12410 box and I am having a problem with E3 link, when the other side is a 7200 router.
After the upgrade, sometimes the link becomes down, but, more frequently, I is up with CRC. The link flaps all the time. I have changed the "national bit", "framing", scramble, etc. Sometimes it works for some minutes, but we haven't found a solution.
Does anybody have experienced this problem?
Best regards.
José Felipe
10-14-2009 07:57 AM
Can you prove it was working fine before the upgrade ?
If you can't, it's a circuit issue and you should complain to telco.
10-14-2009 08:10 AM
Unfortunately is not a circuit issue, we have checked it. Is is happening in different places, always when we do the upgrade to IOS XR.
Thanks.
10-14-2009 08:14 AM
So you will have to revert to older IOS to have things working, and contact the TAC so they can suggest a fixed release or workaround.
10-14-2009 11:18 AM
Hello Jose Felipe,
First thing stop migration activity.
we are introducing C12410 with IOS XR 3.8 to replace GSRs with IOS.
We have E3 circuits and we have seen them flapping from time to time (more then with IOS GSR) but links can be used.
Open a TAC service request and consider to upgrade to IOS XR 3.8
Hope to help
Giuseppe
10-14-2009 02:53 PM
Hello Giuseppe,
thanks for the answer.
what is strange, it always happens when the other side is a 7200. We have E3 links to 7600 and it works fine.
Our customer have a TAC service open, but there is not a conclusion yet.
Regards.
José Felipe
