e3200 low wifi speeds
Rayz_Ryd_1
Hi all.
I have the following setup:
Comcast "Blast!" coming in the wall @ 50Mbps
Motorola SB6121 Modem
Cisco e3200 router
HP Pavilion dv6-6135dx with a ralink rt5390 wireless adapter
The problem is I get about 50mbps (speedtest.net) when hooked direct to modem and about 50mbps when wired directly to router. But as soon as I go wireless, I drop to about 17mbps.
All the equipment should support higher speeds. I would expect a drop in speed on wireless but not that much.
my computer is in the same room about 10 feet away.
any thoughts??
paolo bevilacqua
Wrong forum, post in 'small business - routers". You can move your post using the actions panel on the right.
