What is "csdb tcp synwait-time, tcp idle-time, ....."?
TATSUO YAMADA
Hi Guys,
In IOS 15.2(4)M2 , I found unfamiliar global configuration statements shown below.
Unfortunately, I could not found any references about it.
Does anyone knows what is it or where is documents for it?
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
Tatsuo, Yamada
9 Replies 9
Tom Watts
I Tatsuo, I think this is referencing Cisco NetMgmt DB. which are registered TCP/UDP port 43441.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thank you Tom.
These are parameters for working with CiscoWorks LAN Management Solutions.
but We are not trying to use CiscoWorks LAN Management Solutions.
Does anyone knows how to hide them?
"#no csdb..." or "#csdb tcp ... "  could not hide them.
Hi tatsuo
You post your question in a wrong forum, post in " Network Infrastructure > WAN, Routing and Switching". You can move your post using the actions panel on the right.
Greetings
Johnnatan Rodríguez Miranda
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Hi Tatsuo Yamada,
Per Jonathan's suggestion, I have moved your post into the correct community area.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Sorry for wrong post.  Thyank you for correcting.
Tatsuo, Yamada
Michael Zink
Was this ever answered anywhere?  To where was this thread moved?
When I search in the upper right for csdb, it jut takes me back to this thread.
Reuben Farrelly
Level 3
Level 3
The display of these parameters was a cosmetic bug in 15.2(4)M2.  Upgrade to 15.2(4)M3 and these statements will disappear (hidden).
InayathUlla Sharieff
Hi Tatsuo,
Its been recorded in the following bug:
CSCud25443
Kindly consider the upgrade as suggested by Reuben.
Inayath
*plz rate the usefull posts.
Thank you for the information and take care!
