eBGP between xrv and Juniper Routers
Saskiaaa
Hello everyone,
i  configured   eBGP session between IOS XRV and VMX Routers, but still the BGP state on ACTIVE. can someone help me please to solve this problem.
Configurations in IOS XRV Router:
interface Loopback0
ipv4 address 10.100.100.3 255.255.255.255
interface MgmtEth0/RP0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
ipv4 address 10.100.21.2 255.255.255.0
interface GigabitEthernet0/0/0/1
ipv4 address 10.100.20.2 255.255.255.0
interface GigabitEthernet0/0/0/2
ipv4 address 10.100.25.2 255.255.255.0
interface GigabitEthernet0/0/0/3
ipv4 address 10.100.26.1 255.255.255.0
interface GigabitEthernet0/0/0/4
ipv4 address 10.100.27.1 255.255.255.0
interface GigabitEthernet0/0/0/5
ipv4 address 10.100.25.1 255.255.255.0
router bgp 64522
bgp router-id 10.100.100.3
address-family ipv4 unicast
  network 10.100.100.3/32
neighbor 10.100.20.1
  remote-as 64533
  update-source Loopback0
neighbor 10.100.21.1
  remote-as 64533
end
RP/0/RP0/CPU0:cisco1#show bgp summary
Tue Mar 16 19:29:02.536 UTC
BGP router identifier 10.100.100.3, local AS number 64522
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000   RD version: 3
BGP main routing table version 3
BGP NSR Initial initsync version 3 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process       RcvTblVer   bRIB/RIB   LabelVer  ImportVer  SendTblVer  StandbyVer
Speaker               3          3          3          3           3           0
RP/0/RP0/CPU0:cisco1#show bgp table
Tue Mar 16 19:29:49.367 UTC
Neighbor        VRF                   Spk    AS   TblVer  InQ OutQ  St/PfxRcd
Configurations in VMX Router:
    lo0 {
        unit 0 {
            family inet {
                address 10.100.100.1/32;
routing-options {
    autonomous-system 64533;
root@VMX1# run show configuration protocols bgp
group external-peers {
    type external;
    peer-as 64522;
    neighbor 10.100.20.2;
    neighbor 10.100.21.2;
group internal-bgp {
    type internal;
    local-address 10.100.100.1;
    neighbor 10.100.100.2;
root@VMX1# run show bgp summary
Threading mode: BGP I/O
Groups: 2 Peers: 3 Down peers: 3
Table          Tot Paths  Act Paths Suppressed    History Damp State    Pending
inet.0
                       0          0          0          0          0          0
Peer                     AS      InPkt     OutPkt    OutQ   Flaps Last Up/Dwn State|#Active/Received/Accepted/Damped...
10.100.20.2           64522          0          0       0       0     4:23:33 Active
10.100.21.2           64522          0          0       0       0     4:23:33 Active
10.100.100.2          64533          0          0       0       0     1:01:30 Active
2 Accepted Solutions
Harold Ritter
Hi Saskiaaa,
There is a couple of things missing.
1. Since you want to establish the session to the directly connected IP address of the neighbor, you need to remove the "update-source Loopback0" from both neighbors on the XRv side.
2. You need to enable at least one address family on the XRv side and Juniper side as well.
XRv side:
Juniper side:
    type external;
    peer-as 64522;
    family inet;
3. You need an ingress route policy by default in XR, but if this is a lab exercice you could disable the default behavior with the following configuration.
router bgp 64522
bgp unsafe-ebgp-policy
If you want to export the loopback interface IP address from JUNOS to XR or vice versa, you would configure something like this:
XR:
router bgp 64522
JUNOS:
set protocols bgp group external-peers export loopback
set policy-options policy-statement loopback term 1 from protocol direct
set policy-options policy-statement loopback term 1 from interface lo0.0
set policy-options policy-statement loopback term 1 then accept
6 Replies 6
Harold Ritter
Hi Saskiaaa,
XRv side:
Juniper side:
    type external;
    peer-as 64522;
    family inet;
router bgp 64522
Hi Harold,
i removed and nothing change.
I edited my original post to include a few more things.
Thank you mr Harold, its look better now. did you know how i can advertise the connected networks ( for example loopback )  on VMX side ?
[edit]
Groups: 2 Peers: 3 Down peers: 1
inet.0
                       2          1          0          0          0          0
10.100.20.2           64522         11          8       0       0        3:42 Establ
  inet.0: 1/1/1/0
10.100.21.2           64522          7          4       0       0        1:40 Establ
  inet.0: 0/1/1/0
10.100.100.2          64533          0          0       0       0     1:45:23 Active
Speaker               7          7          7          7           7           0
Neighbor        Spk    AS MsgRcvd MsgSent   TblVer  InQ OutQ  Up/Down  St/PfxRcd
10.100.20.1       0 64533       6       8        7    0    0 00:02:10          0
10.100.21.1       0 64533       2       4        7    0    0 00:00:08          0
XR:
router bgp 64522
JUNOS:
thank you very much!
