eBGP Multihoop
syedasimtaqvi
Hi, I am facing an issue over running e-bgp multi hoop.
My router are advertising and my neighbors are up but my traffic is not floating and I am unable to ping advertised networks.
My end to end routers have hoop of almost 5 routers. WAN to wan connections are reachable over multi hoop and pingable as well.
Similar case is given below,
https://learningnetwork.cisco.com/thread/124608
but is  their any other solution than GRE ?.
2 Accepted Solutions
rasmus.elmholt
Level 7
Level 7
As long as the intermediary devices don't know your internal routing table there is no other way to do this than tunnelling.
GRE i not the only solution you could use an IPinIP to cut down on the headers.
rasmus.elmholt
Level 7
Level 7
Thanks rasmus,
Can you provide a template or some helping example to implement.  IPinIP ?
So its a tunneling type.
well Thanks.
