eBGP neighbourship
Srin_G
Level 3
Level 3
Can we form eBGP neighborship b/w two peers where one peer take physical interface address of remote-peer and 2nd peer taking loopback address of remote-peer?
8 Replies 8
Yes I think
first you must sure that LO is learn from IGP
the config ebgp multi-hop
and it will work.
  Yes you can but you need to do some ajustments.
Use :
neighbor x.x.x.x remote-as xxxx
neighbor x.x.x.x update-source loopback x
neighbor x.x.x.x ebgp-multhop 2
Srin_G
Level 3
Level 3
Thanks for the replies! What is the rationale behind increasing the multihop value? could you please explain?
eBGP is meant to be configured between two physical interfaces and for security reason it consider one hop away; a BGP speaker have a TTL of one. When you use Loopback, you are using more then one hop to get to the other router´s interface. that´s why you need to use multhop option.
Hello
The prefered way to peer direct ebgp neighbours via thier loopbacks (physically 1 hop away) would keep the TTL to 1 but disable the nexthop check (no  ebgp-multhop required)
neighbour x.x.x.x disable-connected-check
Kind Regards
Paul
If the  EBGP session to an IP address on a directly connected router does not belong to a directly connected subnet, it is preferred to use the neighbor disable-connected-check statement.
for me best answer why and where we use multi-hop and disable-connected-check is found in below link
https://ccieblog.co.uk/bgp/bgp-disable-connected-check-vs-ebgp-multi-hop
emurray
Yes, you have to configure the source loopback address on the router you will be using the loopback as the peer. Otherwise, he will keep using the outgoing interface IP address for the keepalive and all BGP-related traffic
Router1(config-bgp)# neighbor 172.16.222.2
Router1(config-bgp-neighbor)# remote-as 65005
Router1(config-bgp-neighbor)# update-source 5.5.5.5
On the router that is peering with the neighbor with a loopback interface
neighbor 5.5.5.5 ebgp-multihop 2
