eBGP Peering through an ASA problem
alanfox987
Hey guys,
I'm having an issue setting up an eBGP peering through an ASA in GNS3 (implementing this on my production equipment in the near future) and can't seem to figure out the problem.  If I connect these two routers through the ASA, the peering fails.  If I connect the two routers directly and change the static routes to point to the new next hops, it works.  So I'm inclined to think my ASA is preventing the BGP connection from establishing.  There are some additional configuration items in the configs below that aren't necessarily pertinent to this problem, as the ultimate goal for this project is to setup BGP over GRE over IPsec using a 6500 & ASA on my end, and a router on their end (presumably using VTI ipsec protection profiles).. but I'm just starting off with getting the BGP peering up.  And I'm not even totally sure if I'm doing that properly (or if this is possible)..  Unfortunately it's been a little while since I've worked with these technologies and I'm a bit lost..
Topology:                 R1 -------------------- ASA -------------------------- R2
Router1#sh run
Building configuration...
Current configuration : 1788 bytes
version 12.4
hostname Router1
boot-start-marker
boot-end-marker
logging buffered 4096 critical
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
interface Loopback0
ip address 10.217.81.25 255.255.255.248
interface Tunnel1
description GRE-TUNNEL-1
ip address 192.168.101.10 255.255.255.252
tunnel source Loopback0
tunnel destination 10.174.171.12
interface FastEthernet0/0
ip address 10.217.81.22 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.2.2.3 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
duplex auto
speed auto
router bgp 2
no synchronization
bgp log-neighbor-changes
network 10.2.2.0 mask 255.255.255.0
neighbor 10.174.171.12 remote-as 1
neighbor 10.174.171.12 ebgp-multihop 25
neighbor 10.174.171.12 update-source Loopback0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.217.81.17
ip route 10.174.171.0 255.255.255.0 10.217.81.17
no ip http server
no ip http secure-server
ip access-list standard BGP-ROUTES
permit 0.0.0.0
route-map BGP-ROUTES permit 10
match ip address BGP-ROUTES
<omitted>
end
ASA# sh run
: Saved
ASA Version 8.4(2)
hostname ASA
interface GigabitEthernet0
nameif inside
security-level 100
ip address 10.217.81.17 255.255.255.248
<omitted>
interface GigabitEthernet5
nameif outside
security-level 0
ip address 10.1.1.1 255.255.255.0
ftp mode passive
object network VPN-DYNAMIC-HOSTS
subnet 10.251.0.0 255.255.240.0
object network VPN-STATIC-HOSTS
subnet 10.251.4.0 255.255.255.0
object network obj-10.217.81.25-32
host 10.217.81.25
description Catalyst 6513 Loopback0
object network obj-10.174.171.12-32
host 10.174.171.12
description ISP
access-list VPN-ACL extended permit ip any 10.251.0.0 255.255.240.0
access-list VPN-ACL extended permit tcp host 10.217.81.25 host 10.174.171.13 eq bgp
access-list VPN-ACL extended permit tcp host 10.217.81.25 host 10.174.171.12 eq bgp
access-list VPN-ACL extended permit ip any 10.251.4.0 255.255.255.0
access-list inside-out extended permit tcp any host 10.174.171.12 eq bgp
access-list inside-out extended permit ip any any
access-list outside-acl extended permit ip any any
tcp-map OPTION-19
  tcp-options range 19 19 allow
pager lines 24
logging enable
logging buffer-size 10240
logging buffered critical
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group outside-acl out interface inside
access-group inside-out out interface outside
route outside 0.0.0.0 0.0.0.0 10.1.1.2 1
route inside 10.2.2.0 255.255.255.0 10.217.81.22 1
route outside 10.174.171.0 255.255.255.0 10.1.1.2 1
route inside 10.217.80.0 255.255.248.0 10.217.81.22 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set VPN-TSET esp-aes-256 esp-sha-hmac
crypto map outside_map 19 match address VPN-ACL
crypto map outside_map 19 set peer 10.174.171.12
crypto map outside_map 19 set ikev1 transform-set VPN-TSET
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group 10.174.171.12 type ipsec-l2l
tunnel-group 10.174.171.12 ipsec-attributes
ikev1 pre-shared-key *****
class-map BGP
match port tcp eq bgp
class-map INSPECT
match any
policy-map INSPECT
class INSPECT
  inspect icmp
class BGP
  set connection random-sequence-number disable
  set connection advanced-options OPTION-19
service-policy INSPECT global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:75f708fe7b6e1e46a7430d709c10b69a
: end
R2#sh run
Current configuration : 1843 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
crypto keyring kr1
  pre-shared-key address 10.217.81.17 key cisco
crypto isakmp policy 1
encr aes 256
authentication pre-share
crypto isakmp profile ikp1
   keyring kr1
   match identity address 10.217.81.17 255.255.255.255
crypto ipsec transform-set ts1 esp-aes esp-sha-hmac
crypto ipsec profile ip1
set transform-set ts1
set isakmp-profile ikp1
interface Loopback0
ip address 10.174.171.12 255.255.255.0
interface Loopback1
no ip address
interface Tunnel0
ip address 192.168.101.9 255.255.255.252
tunnel destination 10.217.81.25
tunnel protection ipsec profile ip1
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
ip address 10.3.3.4 255.255.255.0
duplex auto
speed auto
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
router bgp 1
no synchronization
network 10.3.3.0 mask 255.255.255.0
neighbor 10.217.81.25 remote-as 2
neighbor 10.217.81.25 ebgp-multihop 25
neighbor 10.217.81.25 update-source Loopback0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip route 10.217.81.0 255.255.255.0 10.1.1.1
no ip http server
<omitted>
end
I have been fiddling with the ACLs and some other things, but a syslog message that I'm getting on both ends looks like this (with different IPs based on the router):
*Mar  2 04:50:52.556: BGP: 10.217.81.25 open failed: Connection timed out; remote host not responding, open active delayed 32705ms (35000ms max, 28% jitter)
Thanks for any assistance..
2 Accepted Solutions
There is a lot to look through here. But one of the things I am noticing is that the ASA is doing an inspect on BGP and I wonder if that is the issue. As a test, would you be able to remove the inspect for BGP from the ASA?
Rick
Rick
Hello Alan,
As Robert suggested, remove service policy from configuration ->
no service-policy INSPECT global
BGP session will imediatelly go UP.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
7 Replies 7
alanfox987
By the way, I can ping the loopbacks across from R1 to R2 and it works.
Rick
Rick
do you want to run eBGP through the tunnel?
In that case, you should use the tunnel internal addresses (192.168.101.10 and 192.168.101.9) as the BGP neighbor addresses (and update-sources).
And you should not need
neighbor .... ebgp-multihop 25
command in that case.
Best regards,
Milan
Thanks for the responses, guys.
@Richard: I am disabling random sequence numbers and allowing TCP Option 19 to allow BGP authentication to function through the ASA.  But I'll give it a shot and have a response tomorrow.
@Milan: Thanks for the clarification.  Makes a lot of sense and was confusing me.  I might need to do that during the actual implementation, and your advice will definitely be helpful then.
Hello Alan,
Refer below document ,It might help you
ASA/PIX: BGP through ASA Configuration Example
Ashish Shirkar
Community Manager-NI
Hello Alan,
Best Regards
Thanks for the responses, guys.  Removing the service-policy worked.  I enabled ICMP inspection so I wouldn't have to setup an ACL on both sides to allow pings for testing.  Now I just have to figure out why that was killing the BGP session.. and to get this traffic encrypted over the tunnel.
