eBGP to eigrp redistribution issue
Vinayaka Raman
Please take a look at the file attached and help me understanding why eBGP to eigrp redistribution is failed.
Regards Vinayak
cadet alain
FD is inaccessible
can you try this:
route-map routes-from-x permit 10
match ip address prefix-list routes-from-x
set metric 65000 40 255 1 1500
route-map routes-from-x permit 20
set metric 65000 60 255 1 1500
then verify on eigrp neighbour that the prefixes are in the RIB as D EX
Alain
7 Replies 7
Hello
Try giving disabling auto-summarization in eigrp and give the ebgp routes an eigrp metric
router eigrp 1
no auto-summary
redistribute bgp 65457 route-map routes-from-x metric 1 1 1 1 1
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
cadet alain
FD is inaccessible
can you try this:
Alain
I will update you when I get a chance to implment this metric change..thanks for the inputs..
Regards Vinayak
Hi, I used the metric what alain have suggested and it worked fine..
I have duplicated the old metric values from one of the production router..(config posted below)
Only the bandwidth value is changed to 65000 in my original config..(refer my attachment above)
Can you please explain what went wrong in my original config and how does below config with a load of 255 can work without issues?
CR1#show run | s r eigrp
router eigrp 1
redistribute static metric 64 150 150 150 1500
redistribute bgp 65457 metric 60000 50 255 255 1500 route-map bgp2eigrp
network 10.1.201.0 0.0.0.255
network 10.48.0.0 0.0.0.3
network 10.48.0.4 0.0.0.3
network 10.200.1.2 0.0.0.0
network 10.0.0.0
network 100.0.0.0
no auto-summary
CR1#show route-map bgp2eigrp
route-map bgp2eigrp, permit, sequence 10
  Match clauses:
    ip address (access-lists): bgp2eigrp
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
CR1#show ip route 100.9.254.0
Routing entry for 100.9.254.0/24
  Known via "bgp 65457", distance 20, metric 0
  Tag 65000, type external
  Redistributing via eigrp 1
  Advertised by eigrp 1 metric 60000 50 255 255 1500 route-map bgp2eigrp
  Last update from 152.177.133.9 1w3d ago
  Routing Descriptor Blocks:
  * 152.177.133.9, from 152.177.133.9, 1w3d ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 65000
Regards Vinayak
Hello Vinayaka,
>> I used the metric what Alain have suggested and it worked fine.
So you should rate Alain's post as it solved your issue.
I did it for you
a) you are setting a seed metric for redistribution so any acceptable value can be used, load can be 255
b) with default K settings load is NOT used for metric calculation so the actual value of the load metric component is a don't care.
c)
CR2#show ip ei top 10.60.16.0/22
EIGRP-IPv4 Topology Entry for AS(1)/ID(10.46.0.254) for 10.60.16.0/22
  State is Passive, Query origin flag is 1, 0 Successor(s),>>>> FD is 4294967295>>
  Descriptor Blocks:
  100.190.15.7 (GigabitEthernet0/0), from 100.190.15.7, Send flag is 0x0
      Composite metric is (55552/55296), route is External
      Vector metric:
        Minimum bandwidth is 60240 Kbit
        Total delay is 510 microseconds
        Reliability is 255/255
        Load is 255/255
        Minimum MTU is 1500
        Hop count is 1
      External data:
        Originating router is 10.200.1.1
        AS number of route is 65457
        External protocol is BGP, external metric is 0
        Administrator tag is 65000 (0x0000FDE8)
Edit:
I don't see the difference between your configuration and the one proposed by Alain.
Hope to help
Giuseppe
Thanks for your participation...
I thought I could rate some one after i get my doubt cleared completely..But I am ok you have resolved it ..I still seek some clarification...
In my original post, I have used a route-map like below and it did not work..the topology table entry you see in the attachement is from a different eigrp peer. not from the own router redistribution
set metric 65000 40 255 255 1500
set metric 65000 60 255 255 1500
Alian has suggested me to use like this..it started working..
the only change i see is the load value in the metric. So my question was on the load and you told me that it will not make any difference.
The other thing that confused me is, I have routers in my environment that use redistribution map with a load of 255 and it works fine there.
Regards Vinayak
Hello Vinayaka,
now I see your point, in my work I have always used a seed load component metric of 1 with no problems.
What is the difference between the routers  ( model , IOS flavor (IOS, IOS XR, NX-OS)  IOS version.?
We cannot know if a particular EIGRP implementation checks for load component value and reacts to a  value of 255 in the way that Alain has noted.
For example for NX-OS in the forums several differences have been pointed out.
As a general guideline when choicing a seed metric for redistribution staying away from extreme values is wise.
So let me say that I have changed my idea, the load component should be a don't care but in some implementations there is a sort of check of it. This is only a guess.
There is a Cisco expert in the field of  EIGRP that may be able to explain the differences in implementation.
He sometimes answers to questions about EIGRP implementation in the forums. But I am missing his name he may be Philip Safer or something like this
Or we can wait for good Peter Paluch to join the discussion.
Hope to help
Giuseppe
