877W and O2 (after recent changes)
KiloBravo
Can't get my router to work with the new settings that o2 have supplied/applied. It was a static IP but I've had them change it back to dynamic to see if maybe I can get it working with that. Below is the config I currently have though I have tried various other tweaks:
bridge irb
interface ATM0
mac-address [MAC of o2 box]
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address dhcp
ip access-group OUT-IN in
ip nat outside
ip virtual-reassembly
atm route-bridged ip
pvc 0/101
  oam-pvc manage
  encapsulation aal5snap
At present the ATM interface comes up as does the sub interface, but it doesnt receive an IP address. It works with the o2 box without an issue. These are the seetings that O2 give for this new connection:
http://www.o2help.co.uk/broadband-settings/
I did a debug on the ATM and I get this repeatedley:
*May  9 04:06:12.751: ATM0:atmsar_oam_enqueue_vc,pak = 0x82C7838C
*May  9 04:06:12.751: atmsar_vc_tx_start(82EBC574).
*May  9 04:06:12.751: atmsar_transmit_pak_wrapper: deq(82C7838C). vcd: 2.
*May  9 04:06:12.751: atmsar_transmit_pak_wrapper : encap = Raw
*May  9 04:06:12.767: atmsar_raw_rcv: pak->if_input = 0x82EBD100,
          pak->if_input->hwptr = 0x82EBC574 encap = 0x0ip int
Any idea what else I can try?
Thanks.
2 Accepted Solutions
Are you sure about that ACL? To me that looks like it would deny any IP packet inbound on the interface.
Try removing the ACL from the ATM sub-interface and see if the issue persists.
Paul
****Please rate useful posts****
HTH Paul ****Please rate useful posts****
6 Replies 6
mfurnival
Level 4
Level 4
What does your ACL called OUT-IN do?
Could it be a PPP authentication issue? Do a "debug ppp authentication" and reset the interface.
ip access-list extended OUT-IN
deny   tcp any any
deny   udp any any
deny   icmp any any
deny   ip any any
denies any outside sourced traffic in , I had this on there before the network change and it worked fine.
have run a debug PPP authentication and negotiation, but it returns nothing, I dont believe it even gets to that stage.
Paul
KiloBravo
I just noticed that deny   ip any any at the bottom of the ACL after i pasted it in! I dont even remember typing that in there. That must be it! will remove it when i get home and report back.
Thanks in advance, i'm 99% sure thats been the cause of all my problems.
KiloBravo
All working. Silly me, was fixated on the ATM settings and missed something as basic as that.
Thanks for that guys.
