eBGP vpnv4 route ping failure
We have faced routing issue with
bgp
 We can see
vrf routes
which learns from
ebgp peer
Routes installed in
vrf routing
table but ping is fail. between
ebgp peers  runs ISIS as IGP
Between
ebgp peers
have one node and it is runs as transit role. in this transit routers have isis and mpls. remote
ebgp peer learns vrf router
from
ibgp peer.
We can see  routes in both side. Everthing seems normally but ping is fail
Simple topology have attached
Hi @ElshanMammadli5597 ,
1. Can you replace
ebgp-multihop 10 by ebgp-multihop 10 mpls on both NCS55A2 and Remote N540L
2. Can you provide the output for
show cef vrf azercell 10.22.99.0/24 det from NCS55A2
19 Replies 19
CE-PE-P-PE-CE
you want to ping from
PE to CE
if Yes
use ping vrf x.x.x.x source interface/IP <PE IP in same VRF>
Thanks . Yes i try to ping from PE to PE and to CE like
ping vrf azercell x.x.x.x source interface xxx
But resul is same. ping is unreachible
show ip route vrf azercell 10.130.73.73
share this please
the destination in
RIB VRF
that OK
NOW let check label for this
prefix
show ip bgp vpnv4 vrf azercell 10.130.73.73
The
OS is XR
in router. the command
sintaksis
is not same but similar
this simple lab, I test
ping from PE to CE
same issue as yours and
ping from CE to CE
is success.
in my lab I know exactly what happened, I dont
redistribute
connect into routing protocol (
VRF
aware).
the
show ip bgp vpnv4 all
only display route for
CE's not prefix for connect PE-CE
with
redistribute
connect then I start to appear
sorry I forget to attach this photo
the ping success after I add
redistribute connect in PE R1
M02@rt37
Hello @ElshanMammadli5597,
Please add source to your ping test.
Best regards
i am also try this method. ping from source
 ip.add.
I can see
source ip add in remote side
Maybe issus is releated
mpls and bgp
configuration. I write simple
vpn4 bgp cfg
Maybe we have to add extra attribute
Harold Ritter
It could be that the end to end LSP is not setup properly.
From the
NCS55A2
can you perform the following command to verify whether you have a functioning end to end LSP or not.
ping mpls ipv4 10.79.32.130/32 source 172.20.19.17
And from the ASR920:
ping mpls ipv4 172.20.19.17/32 source 10.79.32.130
Also, I see all the
VPNv4 prefixes on the NCS55A2 with a next hop of 10.79.32.102
This is incorrect and breaks the end to end LSP. You should use the
next-hop
unchanged when you announce the
VPNv4 prefixes
from the middle router
(Remote N540L) to the NCS55A2
Hello Mr Harold Ritter
Thanks for detailed information.
In our topology run two
igp
protocols. Between
NCS55A2
and Remote runs
ISIS and runs OSPD
from Remote
N540 direction ASR920. So NCS55A2 dont know 10.79.32.130
I have to
redistrubute isis to ospf
and back to see each other.
Thanks for the info.
I forgot to mention that you need to configure
mpls oam
on all the routers in order to run the
ping mpls
Please make the change on all routers and retry the
ping mpls
command.
I have to
This is expected. When I mentioned that you needed to have an end to end LSP, it didn't mean having one end to end IGP.
Did you also change the configuration on the middle router
(Remote N540L)
to use the
next-hop-unchanged
under the
address-family vpnv4
as follow:
router bgp 65030
neighbor 172.20.19.17
address-family vpnv4 unicast
next-hop-unchanged
Hi @Harold Ritter
mpls oam
have configured end to end. I have also added
next-hop-unchanged
But result is same. We have two route which origin is Remote
N540L
i can not ping that ip add also. I think that issue related to AS number  or
bgp
config and middle router . Becasue
AS34170
is public AS ,
AS65030
is private AS.
