eBGP vpnv4 route ping failure
We have faced routing issue with
bgp
 We can see
vrf routes
which learns from
ebgp peer
Routes installed in
vrf routing
table but ping is fail. between
ebgp peers  runs ISIS as IGP
Between
ebgp peers
have one node and it is runs as transit role. in this transit routers have isis and mpls. remote
ebgp peer learns vrf router
from
ibgp peer.
We can see  routes in both side. Everthing seems normally but ping is fail
Simple topology have attached
19 Replies 19
Hi @ElshanMammadli5597 ,
1. Can you replace
ebgp-multihop 10 by ebgp-multihop 10 mpls on both NCS55A2 and Remote N540L
2. Can you provide the output for
show cef vrf azercell 10.22.99.0/24 det from NCS55A2
Hi @Harold Ritter
It seems that the issue resolved.
Glad to hear that the issue is resolved @ElshanMammadli5597 .
This is due to the default behavior with the
ebgp VPNv4 session in IOS-XR
which is to generate an
implicit-null
label for the remote ASBR. When eBGP multi hop is used between the ASBRs, this label overrides the one learnt via LDP, which causes traffic to be black holed. The
mpls
keyword is required in this specific scenario to prevent the implicit-null label to override the LDP label (or BGP-LU label).
Hi  @Harold Ritter .
Thank you professional approach and detailed information.
You are very welcome @ElshanMammadli5597 and thanks for the feedback
