Echo reply not received on gateway of last resort from specific VLAN's.
Tom
Moved under a previous post.
6 Replies 6
Jaderson Pessoa
@Tom Hello,
Please, check it:
no ip default-gateway 192.168.0.3
I think that your Asus is not enabled OSPF then it will not work.
I suggest to your first, create a three static route in your ASUS and test again, like below;
ip route 10.0.0.1 255.255.255.0 192.168.0.1
ip route 10.1.0.0 255.255.255.0 192.168.0.1
ip route 10.2.0.0 255.255.255.0 192.168.0.1
ip route 10.3.0.0 255.255.255.0 192.168.0.1
if it work, try enable OSPF in your ASUS ROUTER and remove this static routes and test again..
Jaderson Pessoa
*** Rate All Helpful Responses ***
Thanks very much @Jaderson Pessoa !
Just caught that I left 192.168.0.3 in there too.
This sounds like a plan.  Let me try this step by step and report back.
Thx,
ok, greate.
But right now, just create it to 192.168.0.1
Jaderson Pessoa
Duplicate post -please close this and focus on the the OP you posted.
By the the way in your OP you have the
Asus as 192.168.0.1
ciscoas 192.168.0.3
on here
Asus as 192.168.0.6
ciscoas 192.168.0.1
Kind Regards
Paul
Sure. I'll work off of the original thread.
How to close this?  Took a quick glance but couldn't see anything with close or end post.
Just edit it and remove the text
Kind Regards
Paul
