Router Multiple WAN per VLAN
MulHello, I want some help on this topic.
We want to assign a different WAN IP Address for VLAN.
For example:
 122.221.xxx.xxx - VLAN10
 122.222.xxx.xxx - VLAN20 and so on.  We have 8 available WAN IP Addresses.
So far, we tried to ip NATPOOL like:
object-group network VLAN10
 range 192.168.243.0 192.168.243.255
ip nat inside source list VLAN10-ACL pool VLAN10-NATPOOL
But it does not work.  What I noticed is I can ping 8.8.8.8 no problem but DNS resolution function does not work.  If I tried to say ping google.com, it says unknown host.  Its really strange.
Thanks.
7 Replies 7
that sounds like 'just' a DNS resolution problem with your clients. Which DNS servers are being assigned to your clients ? If you want to ping a domain name from your router, you need to configure:
ip domain-lookup
and a name server, e.g.:
ip name-server 8.8.8.8
@Georg Pauwen   Thank you.
We are using internal DNS server 172.17.1.xxx.  This DNS was working before.
What I did was remove this line:
  ip nat inside source list CC2-ACL pool CC2-NATPOOL
Like do I need to create an ACL to permit DNS for CC2-NATPOOL?
what was in that access list ?
Actually, post the full running configuration of your router...
Are you trying to ping the domain name from the router or from a client (PC) ?
Hello.
Here it is.
I was trying to ping from a client PC not from the router.
thanks in advance.
I am not sure I understand your config, maybe I am missing something:
Where does 192.168.224.0/24 come from ? There is no corresponding interface for, or internal route to, that network.
Also, I don't see a default route for Internet traffic, or did you just omit that ?
object-group network CC2
range 192.168.224.0 192.168.224.255
ip nat pool CC2-NATPOOL 122.211.143.35 122.211.143.35 prefix-length 29
ip nat inside source list Internet-ACL interface GigabitEthernet0/0 overload
ip access-list extended CC2-ACL
deny ip object-group CC2 object-group INTERNAL
permit ip object-group CC2 any
>>> Sorry it should be 192.168.243.0/24.  Now it is  range 192.168.224.0 192.168.224.255  but if I change to range 192.168.243.0 192.168.243.255, the problem of Internet occurs and I can ping to 8.8.8.8 but not DNS resolution fails.
Sorry but where should I set the default route for internet traffic?
default routes <172.17.1.1> is another router.
Gateway of last resort is 172.17.1.1 to network 0.0.0.0
D*EX 0.0.0.0/0 [170/28416] via 172.17.1.1, 7w0d, Tunnel1
10.0.0.0/8 is variably subnetted, 97 subnets, 5 masks
D EX 10.1.0.0/16 [170/28672] via 172.17.1.1, 7w0d, Tunnel1
D EX 10.2.0.0/16 [170/28928] via 172.17.1.1, 08:42:13, Tunnel1
D EX 10.3.0.0/16 [170/28672] via 172.17.1.1, 7w0d, Tunnel1
D EX 10.4.2.0/23 [170/28928] via 172.17.1.1, 6w1d, Tunnel1
D EX 10.4.8.0/23 [170/28928] via 172.17.1.1, 7w0d, Tunnel1
range 192.168.224.0 192.168.224.255 >>> should be range 192.168.243.0 192.168.243.255
Hi! even with a default route it did not work.
Although I could resolve the IP to hostnames (it means DNS is working).
Ping to google.com or 8.8.8.8 resulted in time-outs.
Seems like something is blocking internet access.
