ECMP static routes help
vincehgov
I have two routers, A and B, that are connected to each other via two FE links.
Each link has it's own subnet.  Each router also has its own loopback address.
Here is how it looks
   FA 1 -------------------   FA 1
A                                      B
   FA 2 -------------------   FA 2
A FA 1 : 10.1.1.1/30
A FA 2 : 10.2.1.1/30
A LO 0: 172.16.1.1/32
B FA 1: 10.1.1.2/30
B FA 2: 10.2.1.2/30
B LO 0: 172.16.1.2/32
I created 2 static routes on each router to get to the other router's loopback.
On router A:
ip route 172.16.1.2 255.255.255.255 fa 1
ip route 172.16.1.2 255.255.255.255 fa 2
On router B:
ip route 172.16.1.1 255.255.255.255 fa 1
ip route 172.16.1.1 255.255.255.255 fa 2
I still cannot ping the loopback from the other router.  When I shut down one of the ports, it works.  I can ping each of the physical ports fine.
Is this not supported?
cadet alain
is it working when you configure the static routes pointing to next-hop instead of outgoing interface ?
Can you also try with network routes instead of host routes.
Regards.
Alain.
6 Replies 6
cadet alain
Regards.
Alain.
Hi Alain,
I will try with next-hop address when I get to the office.  What do you mean when you say network routes?  Like create a bigger subnet to try instead of the /32?
Vince
yes I mean  ip route 172.16.1.0 255.255.255.0
Regards.
Alain.
Thank you.  Setting the next hop to the ip address rather than out the interface worked.
Do you have an explanation of why that didn't work before?
I mean, why setting the next hop to the interface didn't work.
I labbed it up and here is what is happening when using the outgoing interface in both static routes:
r1(config)#do p 172.16.1.2 so lo0
Sending 5, 100-byte ICMP Echos to 172.16.1.2, timeout is 2 seconds:
Packet sent with a source address of 172.16.1.1
Success rate is 0 percent (0/5)
r1(config)#do debug arp
ARP packet debugging is on
*Mar  1 00:08:53.203: IP ARP: sent req src 10.2.1.1 c200.0a8c.0001,
                 dst 172.16.1.2 0000.0000.0000 FastEthernet0/1
*Mar  1 00:08:53.435: IP ARP rep filtered src 172.16.1.2 c201.0a8c.0001, dst 10.2.1.1 c200.0a8c.0001 wrong cable, interface FastEthernet0/1.
*Mar  1 00:08:55.199: IP ARP: sent req src 10.1.1.1 c200.0a8c.0000,
                 dst 172.16.1.2 0000.0000.0000 FastEthernet0/0
*Mar  1 00:08:55.371: IP ARP rep filtered src 172.16.1.2 c201.0a8c.0000, dst 10.1.1.1 c200.0a8c.0000 wrong cable, interface FastEthernet0/0.
*Mar  1 00:08:57.199: IP ARP: sent req src 10.2.1.1 c200.0a8c.0001,
*Mar  1 00:08:57.347: IP ARP rep filtered src 172.16.1.2 c201.0a8c.0001, dst 10.2.1.1 c200.0a8c.0001 wrong cable, interface FastEthernet0/1.
*Mar  1 00:08:59.199: IP ARP: sent req src 10.1.1.1 c200.0a8c.0000,
*Mar  1 00:08:59.267: IP ARP rep filtered src 172.16.1.2 c201.0a8c.0000, dst 10.1.1.1 c200.0a8c.0000 wrong cable, interface FastEthernet0/0.
*Mar  1 00:09:01.199: IP ARP: sent req src 10.2.1.1 c200.0a8c.0001,
*Mar  1 00:09:01.327: IP ARP rep filtered src 172.16.1.2 c201.0a8c.0001, dst 10.2.1.1 c200.0a8c.0001 wrong cable, interface FastEthernet0/1.
r1(config)#do sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.1                -   c200.0a8c.0000  ARPA   FastEthernet0/0
Internet  10.2.1.1                -   c200.0a8c.0001  ARPA   FastEthernet0/1
Regards.
Alain.
