Edge router choice
rfritz
We are replacing a DS3 Internet connection with a 100 Mbps fastE connection from a Tier 1 Provider.  I currently have a Cisco 7204VXR with 512 Mb DRAM and 128 Mb of Flash and two 10/100 ports that is connected to the DS3.  I also have a 3845 with 1 Gb of DRAM and 256 Mb of Flash with two 10/100/1000 ports available.
We are currently running BGP, below is the summary
BGP table version is 88880414, main routing table version 88880414
379041 network entries using 44347797 bytes of memory
379043 path entries using 19710236 bytes of memory
63121/63114 BGP path/bestpath attribute entries using 7827004 bytes of memory
55854 BGP AS-PATH entries using 1469262 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 73354299 total bytes of memory
BGP activity 14231060/13852015 prefixes, 17323428/16944385 paths, scan interval
60 secs
My question is which of these two routers will be best suited for the application? I can upgrade the memory in the 7200VXR if needed.
Roy
rfritz
Forgot to mention the 7204 has a NPE400 and CPU utilization currently is under 10%, highest I have seen the 5 min average was 17%
Roy
The NPE400 is quite outdated. You can upgrade it to an NPE-G1, keeping the same chassis.
A 3845 will work as well.
Don't want to debate here Paolo but my question is based on my education.
What about the NPE-G2 instead?  My reasoning is the amout of BGP required.
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
100 Mbps Ethernet, to guarantee wire-rate, could require about 300 Kpps.  A NPE400 is rated at 400 Kpps, the 3845 at 500 Kpps.  You might, or might not (much depends on your router's configuration, actual traffic load and kinds of traffic), be able to connect the new 100 Mbps to either router.
If you're only going to have about the same traffic on the new link vs. the DS3, you might be just fine.  If not, Paolo's suggestion is good, although you might also want to price compare to the latest ISRs.
I've attached a Cisco documents that describes performance for their various routers.
