EEM Script for Two Point to Point tunnel
CCIE Aspirant
Hi all,
i have one router at my remote site and it has point to point tunnel with our main office router. we have route for all traffic of site to our head office router. and we have EEM script at the remote site that checks the status of the tunnel. if tunnel state goes down the the router reloads and it is because we have sim inside our router and by reloading it, the tunnel comes up.
so now we need to have another router at the head office as backup and incase the main router at head office goes down then the router at site send all the traffic to the backup router.
so in this case i think if we create another tunnel at remote site with backup router and track the status of the tunnel with main router and if it goes down then all traffic will forward to backup router. ( any suggestion on this step).
the problem with that is when tunnel with main router goes down i have script at remote router to reloads. so may be traffic forwarded to backup router but router will again and again reload due to reload script. so is there any suggestion how i can make use of script so that if both tunnel goes down then at that case reload else do nothing.
following is the current confgis and i need help on how to set all things if we deploy backup router as well
track 1 ip sla 1 reachability
 delay down 120 up 1
ip sla 1
 icmp-echo x.x.x.x ( the loopback public IP of tunnel destination at head office )
ip sla schedule 1 life forever start-time now
event manager applet WatchDogApplet
 event timer watchdog name WATCHING time 480
 action 1 track read 1
 action 2 if $_track_state eq "down"
 action 3  reload
 action 4 else
 action 5  syslog msg "timer will reset - No action required"
 action 6 end
I am not sure I fully understand your topology, but if you want nothing to happen when both tunnels go down, you need to
configure a second IP SLA
and then a track list that does something/nothing only when both
IP SLAs are down
ip sla 1
icmp-echo 1.1.1.2 source-ip 1.1.1.1
frequency 5
ip sla schedule 1 start-time now life forever
ip sla 2
icmp-echo 2.2.2.2 source-ip 2.2.2.1
frequency 5
ip sla schedule 2 start-time now life forever
track 3 list boolean or
object 1
object 2
event manager applet NO_ACTION
IP SLAs are down
ip sla 1
frequency 5
ip sla 2
frequency 5
object 1
object 2
thanks for the reply.
i need to reload the router only in case both the tunnel goes down. and incase main tunnel goes down, then all the traffic should be routed to the backup tunnel. only reload should be triggered in case both tunnel are down.
if you cannot work this out, post the running configuration of your router...
