Loading Software on 2951 Error Message: Bad Service Code
Tony T.
Hello-
I'm currently trying to load software on a 2951. The specific software I'm attempting to load is 15.7-3.M7.
I've successfully loaded this software on a different 2951, but one of the 2951's in the lab keeps getting a error message saying:
%Error reading usbflash0:c2951-universalk9-mz.SPA.157-3.M7.bin (Bad service code)
Again, this worked on a different 2951 and the configurations are identical. Specifically, meaning I'm using a USB on both platforms. Simple command:
router#copy usbflash0:c2951-universalk9-mx-SPA.157-3.M7.bin flash0:
I'm not sure what the issue could be. Any assistance is appreciated.
Leo Laohoo
2900 have two USB ports.  What happen if you plug it into the 2nd one?
10 Replies 10
balaji.bandi
is this ROMMON mode?
try dir usbflash0: are you able to read the files?
also, try  dir flash0:
BB
Tony T.
Hey-
The router is not in rommon, and yes, I can see the software in the usb (dir usbflash0:). In fact, I used the same usb when I successfully loaded the same software on a different 2951. Regarding the flash0: directory, I see the old software and other files, nothing abnormal.
Tony
Tony
thanks for the input, when are you getting the above message, while copy? (do you have enough space in the target ?)
BB
Hey again,
Yes, I get the message when trying to copy. And yes, there's more then enough space (417120256 bytes free). The software is only (115327348).
Tony
Looks like some compatible issue with USB, is this FAt 32 formatted? what size of the US stick?
when you mention another device that can use the same USB ? is this the same model? what is the IOS Code running on that?
when you insert the USB what Log you see?
can you post dir usbflash0:
show version working vs not working device?
BB
Hello-
Don't know if the USB is formatted, I suspect so. Also, the size is good, there's alot of space left.
Yes, the platforms are exactly the same. They both had the same software 15.1.
I see no logs when I insert the USB.
No, I can't show what the output is when I type command "dir usbflash0:"
I'm not sure what you're asking in the last sentence.
Tony
2951 has two USB ports at the back.  You've connected the USB stick in port 0.  Can you see port 1?
Cisco appliances are very "picky" about what USB brand support.
What is universally known is the maximum size is 16 Gb and needs to be formatted to FAT16.
Leo Laohoo
Hey Leo-
I think I tired the other USB port but I can't recall. Will try tomorrow and let you know what happens.
Tony
Leo-
The second usb port worked. Thanks for the assistance.
Tony
