EEM script not getting into "enable" mode
manish chandela
Hi All,
I am having issues running my EEM script. The script is used to edit the prefix-list, based on the packets received at the interface.
When I run the debug, I see that the script is indeed triggered but unable to get into the "enable" mode. Any idea?
002261: Nov 21 22:28:44.972 CST: Name-Value Pair: Name=(tcl) Value=(xos_if_type)
002262: Nov 21 22:28:44.972 CST: Pushing tag <fh_var> on to stack
002263: Nov 21 22:28:44.972 CST: open tag is <fh_var>
002264: Nov 21 22:28:44.972 CST: Popping tag <fh_var> off stack
002265: Nov 21 22:28:44.972 CST: close tag is </fh_var>
002266: Nov 21 22:28:44.972 CST: Name-Value Pair: Name=(pdir) Value=(_if_short)
002267: Nov 21 22:28:44.972 CST: Name-Value Pair: Name=(tcl) Value=(if_short)
002268: Nov 21 22:28:44.972 CST: Pushing tag <fh_var> on to stack
002269: Nov 21 22:28:44.972 CST: open tag is <fh_var>
002270: Nov 21 22:28:44.972 CST: Popping tag <fh_var> off stack
002271: Nov 21 22:28:44.972 CST: close tag is </fh_var>
002272: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_event_type value:71
002273: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_event_type_string value:interface
002274: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
002275: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_name value:GigabitEthernet0/0/5
002276: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_parameter value:receive_rate_pps
002277: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_is_increment value:FALSE
002278: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_value value:1221
002279: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_delta_value value:-7
002280: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_interface_exit_event value:0
002281: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_if_xos_if_handle value:13
002282: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_if_xos_if_type value:6
002283: Nov 21 22:28:44.973 CST: EEM: policy_dir xml builtin: name:_if_short value:Gi0/0/5
002284: Nov 21 22:28:44.973 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : CTL : cli_open called.
002285: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : C
002286: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ***********************************************************
002287: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Property
002288: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Location:
002289: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Model: Cisco ASR 1002
002290: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : BGP
002291: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Cisco
002292: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Ci -
002293: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Ci
002294: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ***********************************************************
002295: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002296: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002297: Nov 21 22:28:44.975 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN :ASR1002-INET>enable
002298: Nov 21 22:28:44.976 CST: cli_history_entry_add: free_hist_list size=0, hist_list size=7
002299: Nov 21 22:28:44.976 CST: eem_no_scan flag set, skipping scan of command_string=connect enable
002300: Nov 21 22:28:44.987 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Translating "enable"
002301: Nov 21 22:28:44.987 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002302: Nov 21 22:28:44.987 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Bad IP address or host name% Unknown command or computer name, or unable to find computer address
002303: Nov 21 22:28:44.987 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002304: Nov 21 22:28:44.987 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>config t
002305: Nov 21 22:28:44.999 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ^
002306: Nov 21 22:28:44.999 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
002307: Nov 21 22:28:44.999 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002308: Nov 21 22:28:44.999 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002309: Nov 21 22:28:44.999 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>ip prefix-list allow-public-out seq 5 deny 0.0.0.0/0
002310: Nov 21 22:28:45.111 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ^
002311: Nov 21 22:28:45.111 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
002312: Nov 21 22:28:45.111 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002313: Nov 21 22:28:45.111 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002314: Nov 21 22:28:45.111 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>no ip prefix-list allow-public-out seq 10 permit x.x.x.0/24
002315: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : no ip prefix-list allow-public-routes-out seq 10 permit x.x.x.0/24
002316: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ^
002317: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
002318: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002319: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002320: Nov 21 22:28:45.223 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>route-map allowed_out permit 10
002321: Nov 21 22:28:45.334 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ^
002322: Nov 21 22:28:45.334 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
002323: Nov 21 22:28:45.334 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002324: Nov 21 22:28:45.334 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002325: Nov 21 22:28:45.334 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>no set community no-export
002326: Nov 21 22:28:45.446 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ^
002327: Nov 21 22:28:45.446 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
002328: Nov 21 22:28:45.446 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002329: Nov 21 22:28:45.446 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002330: Nov 21 22:28:45.446 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : IN : ASR1002-INET>end
002331: Nov 21 22:28:45.451 CST: cli_history_entry_add: free_hist_list size=0, hist_list size=7
002332: Nov 21 22:28:45.451 CST: eem_no_scan flag set, skipping scan of command_string=connect end
002333: Nov 21 22:28:45.458 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : Translating "end"
002334: Nov 21 22:28:45.458 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT :
002335: Nov 21 22:28:45.458 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : % Bad IP address or host name% Unknown command or computer name, or unable to find computer address
002336: Nov 21 22:28:45.458 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : OUT : ASR1002-INET>
002337: Nov 21 22:28:45.458 CST: %HA_EM-6-LOG: PPS : DEBUG(cli_lib) : : CTL : cli_close called.
002338: Nov 21 22:28:45.458 CST: fh_server: fh_io_ipc_msg: received msg FH_MSG_CALLBACK_DONE from client 154 pclient 1
002339: Nov 21 22:28:45.458 CST: fh_io_ipc_msg: EEM callback policy DDoS-PPS has ended with normal exit status of 0x0
002340: Nov 21 22:28:45.458 CST: EEM fms_remote_chkpt_add_event_hist(), data_len = 2984, buf_size = 2996
002341: Nov 21 22:28:45.458 CST: EEM: server decrements in use thread: jobid=151 rule id=2 in use thread=0.
002342: Nov 21 22:28:45.458 CST: fh_schedule_callback: fh_schedule_callback: cc=7F269711B368 prev_epc=7F26A243D610; epc=0
002343: Nov 21 22:28:45.458 CST: ter
Any help will be appreciated.
Many thanks
Vinit Jain
This issue could be due to the privilege level of the user when you are running the EEM script. You might be getting privilege level 0 and performing command authorization. Could you please configure "event manager session cli username <usr>" where usr is the username which is authorized to get into enable mode and run the commands that you are trying to run.
Hope this helps
Vinit
PS: Please rate useful posts.
--Vinit
Hi Vinit,
I already have that configured and the username has the highest level of access.
event manager session cli username "xxxx"
event manager applet PPS
event interface name GigabitEthernet0/0/5 parameter receive_rate_pps entry-op gt entry-val 100 entry-type value poll-interval 10
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "ip prefix-list allow-public-out seq 5 deny 0.0.0.0/0"
action 4.0 cli command "no ip prefix-list allow-public-routes-out seq 10 permit x.x.x.0/24"
action 5.0 cli command "route-map allowed_out permit 10"
action 6.0 cli command "no set community no-export"
action 7.0 cli command "end"
Anyone?
This output means that the cli user defined doesn't have the privillage for "enable" command. Or maybe you have a view configured which is affecting the defined user.
Mohammad Moghaddas
