ASR 1006 GIG interface MTU issues
nagasheshu2010
Hi All,
Can you please advise if there any limit on MTU size for GIG interface on ASR 1006 router?
I am able to ping P2P link with size 9082 but not with anything greater than 9082.
SPA-2X1GE-V2 is the card type and its same at both ends.
Please help and below are the more details about device and platform.
#sh ver
Cisco IOS XE Software, Version 03.13.01.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.4(3)S1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 31-Oct-14 19:47 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
splidc-gb1 uptime is 41 weeks, 2 days, 3 hours, 51 minutes
Uptime for this control processor is 41 weeks, 2 days, 3 hours, 52 minutes
System returned to ROM by reload at 23:02:25 BRT Wed Feb 11 2015
System restarted at 23:08:35 BRT Wed Feb 11 2015
System image file is "bootflash:asr1000rp2-adventerprisek9.03.13.01.S.154-3.S1-ext.bi"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1006 (RP2) processor (revision RP2) with 9899774K/6147K bytes of memory.
Processor board ID FOX1635G01Q
4 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
3 Packet over SONET interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
1925119K bytes of eUSB flash at bootflash:.
78085207K bytes of SATA hard disk at harddisk:.
# sh platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    41w2d
 0/0      SPA-1X10GE-L-V2     ok                    41w2d
 0/1      SPA-1X10GE-L-V2     ok                    41w2d
1         ASR1000-SIP10       ok                    41w2d
 1/0      SPA-2XOC3-POS       ok                    41w2d
 1/1      SPA-1XOC12-POS      ok                    41w2d
2         ASR1000-SIP10       ok                    41w2d
 2/0      SPA-2X1GE-V2        ok                    2d09h
 2/2      SPA-2X1GE-V2        ok                    2d09h
R0        ASR1000-RP2         ok, active            41w2d
F0        ASR1000-ESP20       ok, active            41w2d
P0        ASR1006-PWR-AC      ok                    41w2d
#sh interfaces gi2/0/0
GigabitEthernet2/0/0 is up, line protocol is up
  Hardware is SPA-2X1GE-V2, address is acf2.c5c5.d180 (bia acf2.c5c5.d180)
    Internet address is 1.1.1.1/30
  MTU 9216 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is LX
  output flow-control is on, input flow-control is on
  Last input 00:00:23, output 00:00:09, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     6136 packets input, 3952928 bytes, 0 no buffer
     Received 23 broadcasts (0 IP multicasts)
     0 watchdog, 671 multicast, 0 pause input
     6841 packets output, 5372222 bytes, 0 underruns
     0 output errors, 0 collisions, 26 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Moh Mogh
I think you are hitting something called "Overload by Packet Fragment".
If packets are fragmented due to the MTU size, even if the ingress interface is less than the wire rate, wire rate can be exceeded at the egress interface. In this case, the packet is dropped at the egress interface.
the output of the following command might be helpful too:
show im database interface gigabitEthernet 0/1/0/3
You can read more here and here.
Mohammad Moghaddas
Vinit Jain
Could you please share the running configuration of both sides of the interface.
Vinit
--Vinit
