Egress Netflow v9 and output packet marking order
abelkacem
Hi all,
I need some help to solve a problem when using egress netflow (v9) and output marking.
The topologie :
Server <-----> R1 1>-----<1 R2 2>----<2 R3
R2 is a 7200 with c7200p-adventerprisek9-mz.124-15.T11.bin
What I'm doing :
- R2 forwards ping packets from Server to R3. When they arrive on R2, icmp packets are marked with CS3
- I change the DSCP to CS4 on R2 before forwarding packet to R3. I'm using for that an output service-policy on the R2-2 interface like this :
interface ATM2/0.36 point-to-point
ip address 192.168.1.1 255.255.255.252
ip flow ingress
ip flow egress
no ip mroute-cache
snmp trap link-status
pvc 1/36
  vbr-nrt 2040 2040 1
  tx-ring-limit 3
  oam-pvc manage
  oam retry 3 5 1
  service-policy output TDSL2C
- I export Netflow v9 data to a management device
What I'm getting:
- On R2, when I enter: sh ip cache verb flow I get this:
AT2/0.36      10.1.1.202    Gi0/3.427            10.255.255.208  01 60  10      10
R2-1            10.255.255.208  AT2/0.326*     10.1.1.202         01 60  10      10
10.255.255.208 is the Server
10.1.1.202 is R3
- As you can see, the line concerning the egress packet (with *) indicates a TOS of 60 in hex => DSCP CS3
- However, on R3 I have:
AT0/0.1        10.255.255.208  Local          10.1..202   01 80  10      10
which is correct (AT0/0.1 is R3-2)
My question:
- Why the egress netflow on R2 indicates a TOS of 60 instead of 80 as I would expect ?
In theory, egress netflow comes after QoS marking, so if I understand, normally on R2 I should have something like :
AT2/0.36      10.1.1.202         R2-1              10.255.255.208  01 60  10      10
R2-1            10.255.255.208  AT2/0.326*     10.1.1.202         01 80  10      10
but in practice I don't, I'm confused !
Amit Aneja
Level 3
Level 3
This should have worked with egress netflow & should have shown the correct DSCP values after marking. I have fixed similar cases using egress netflow.
What is the IOS on R2?
I totally agree with you, in theory this should work.
The IOS on R2 is c7200p-adventerprisek9-mz.124-15.T11.bin
This night I had a flash : may be the odd behaviour is normal with an ATM interface as the service-policy is applied to the PVC and not to the sub-interface itself, what do you think ?
thanks in advance
Can't say whether this beahvior is just with ATM or other interfaces. Guess, it needs some testing.
What I am sure about is that this is unexpected behavior. I tried to look for bugs on this, but couldn't find one. Looks like a new bug to me.
Amit
