EHWIC-3G-HSPA+7 - not supported in vrf setups?
mvoegele
Level 5
Level 5
hi,
we set up a 1941 with c1900-universalk9-mz.SPA.151-4.M3.binand tried to bring up
EHWIC-3G-HSPA+7 in the vrf.
config:
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
ip vrf #99
description internet
rd 10.1.1.1:99
interface Cellular0/0/0
ip vrf forwarding #99
ip address negotiated
encapsulation slip
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
ip route vrf #99 0.0.0.0 0.0.0.0 Cellular0/0/0
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
dialer-list 1 protocol ip permit
Result:
Router#ping vrf #99 4.2.2.2
% VRF #99 does not have a usable source address
Router#
Router#ping vrf #99 4.2.2.2 source cellular 0/0/0
Router#
if we move the cellular 0/0/0 to GRT
Router(config)#int cell 0/0/0
Router(config-if)#sh
Router(config-if)#no ip vrf forw #99
Router(config-if)#ip addr nego
Router(config-if)#no sh
Router(config-if)#end
Router#
Router#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/72/84 ms
Router#
Is this interface not supported in vrf setups?
5 Replies 5
Giuseppe Larosa
Hello Markus,
there is nothing listed in HWIC configuration guide
see
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html#wp1149000
However, the cellular interface is an asynchronus interface ( async mode interactive) and my guess is that this the reason why VRF is not supported on it.
For example for correct support on ISDN BRI or PRI interfaces the command dialer map vrf  aware had been introduced.
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013440
I had the same symptoms with BRI or PRI interfaces
Hope to help
Giuseppe
With the older 3G card the setup is supported, maybe I have to raise an TAC case
Mit freundlichen Grüßen / with best regards
Markus Vögele
Lufthansa Systems AG
Department FRA AI/B-NP
LIC A, Room 2.1.059
Am Weiher 24
D-65451 Kelsterbach
Phone: +49 69 696-9572
Fax: +49 69 696-98-95724
Mobile: +49 151 58920178
E-Mail: markus.voegele@lhsystems.com
Internet:www.LHsystems.com
Von: giuslar
Gesendet: Wednesday, May 09, 2012 04:43 PM
An: VOEGELE, MARKUS
Betreff: - Re: EHWIC-3G-HSPA+7 - not supported in vrf setups?
Home<>
created by Giuseppe Larosa<> in WAN, Routing and Switching - View the full discussion<>
Hello Markus,
I agree it is wise to open a service request
Best Regards
Giuseppe
atle.haukeland
Did you remember to create the layer 2 VLAN?
please refer to design at http://www.cisco.com/en/US/docs/solutions/SBA/August2012/Cisco_SBA_BN_VPNRemoteSiteOver3G4GDeploymentGuide-Aug2012.pdf
You should configure cellular interface and Dialer as well, but as dialer pool.
This worked for me.
The config should be like this:
no ip address
encapsulation slip
dialer in-band
dialer string gsm
dialer-group 1
dialer pool-member 1
int Dialer1
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
Best ragards.
