Cisco 886VA gets no link with Annex-J
Dirk Dietz
Hi all,
i used a Cisco 886VA with Annex-B service in Germany. Now the provider has changed the DSLAM port to Annex-J but the router does not get any connection anymore.
As per Cisco homepage (http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-613481.html) the router should support Annex-J in table 7:
Cisco 886VA: Optimized for Annex B; also compatible with Annex J
Does anyone know how to bring up the router with Annex-J service??
Is there something special i have to configure?
Do i have to buy Cisco 886VA-J???
Software i have tested:
c880data-universalk9-mz.151-4.M4.bin
c880data-universalk9-mz.153-1.T.bin
My Router config:
rt02#show run | b controller vdsl 0
controller VDSL 0
rt02#show run int atm0
interface ATM0
description WAN[ADSL T-COM]
no ip address
load-interval 30
no atm ilmi-keepalive
end
rt02#show run int atm0.1
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
pvc 1/32
  pppoe-client dial-pool-number 1
end
Hope someone can help me here.
Many thanks in advance.
regards
Dirk
paolo bevilacqua
Contact Cisco TAC.
m-reuter
Im also in Germany based.
Do you have the rigt model:
You need:
CISCO886VA-J-K9
Only this model supports Annex-J
Cheers
Marcel
i know, i have already a Cisco 886VA-J but it was hard to get. And now all the suppliers have removed this device from their list. Don't know why as T-COM offers more and more services with Annex-J
And there is a bug between IOS and this type of router which gives you tracebacks for SNMP related to the dedicated DSL-Controller.
Have tried to raise a ticket but the supplier can't open a Cisco case.
There is one strange thing: Why don't we find this router in the list for IOS??
bye
Dirk
