EHWIC-4ESG interfaces not showing on a Cisco 1921 version 15.7(3)M6
razvandunareanu
Hello, I'm having an issue with the EHWIC-4ESG not showing in the interfaces list.
Router#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.7(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Fri 06-Mar-20 04:06 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.157-3.M6.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FCZ1940C2UY
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO1921/K9          FCZ1940C2UY
Suite License Information for Module:'c1900'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
datak9
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
data          None                 None           None
The card is appearing in the inventory and in diag:
Router#show inventory
NAME: "CISCO1921/K9", DESCR: "CISCO1921/K9 chassis, Hw Serial#: FCZ1940C2UY, Hw Revision: 1.0"
PID: CISCO1921/K9      , VID: V05 , SN: FCZ1940C2UY
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 0", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG        , VID: V01 , SN: FOC20044TKA
Router#show diag
Slot 0:
        C1921 Mother board 2GE, integrated VPN and 2W Port adapter, 6 ports
        Port adapter is analyzed
        Port adapter insertion time 00:11:26 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC193136BP
        Hardware Revision        : 1.0
        Part Number              : 73-12850-09
        Top Assy. Part Number    : 800-33408-04
        Board Revision           : E0
        Deviation Number         : 0
        Fab Version              : 02
        Product (FRU) Number     : CISCO1921/K9
        Version Identifier       : V05
        CLEI Code                : CMMHF10ARA
        Processor type           : C8
        Chassis Serial Number    : FCZ1940C2UY
        Chassis MAC Address      : d8b1.90de.a0c0
        MAC Address block size   : 32
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 39 33 31 33 36 42 50 40
          0x10: 06 AC 41 01 00 82 49 32 32 09 C0 46 03 20 00 82
          0x20: 80 04 42 45 30 88 00 00 00 00 02 02 CB 8C 43 49
          0x30: 53 43 4F 31 39 32 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 46 31 30 41 52
          0x50: 41 09 C8 C2 8B 46 43 5A 31 39 34 30 43 32 55 59
          0x60: C3 06 D8 B1 90 DE A0 C0 43 00 20 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 51 40 00 8B 41 00 3C 42 00
          0x80: 00 F8 00 24 03 E8 1B 11 07 D0 1E A2 09 C4 1F A9
          0x90: 0B B8 20 0F 0F A0 20 D3 13 88 21 6A 1B 58 21 A9
          0xA0: 1F 40 21 B8 27 10 21 3E 41 00 50 42 00 00 F8 00
          0xB0: 18 02 71 1D B0 04 E2 20 08 07 53 21 02 0E A6 22
          0xC0: 60 1D 4C 22 C4 27 10 22 C4 FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        4 Port GE Switch
        PCB Serial Number        : FOC20044TKA
        Part Number              : 74-7105-01
        Board Revision           : E0
        Product (FRU) Number     : EHWIC-4ESG
        Version Identifier       : V01
        CLEI Code                : COUIA46CAA
        Base MAC Address         : 00c1.64c4.66b0
        MAC Address block size   : 8
          0x00: 04 FF 40 06 B5 C1 8B 46 4F 43 32 30 30 34 34 54
          0x10: 4B 41 41 01 00 82 4A 1B C1 01 42 45 30 88 00 00
          0x20: 00 00 CB 8A 45 48 57 49 43 2D 34 45 53 47 89 56
          0x30: 30 31 20 D9 03 40 C1 CB C6 8A 43 4F 55 49 41 34
          0x40: 36 43 41 41 CF 06 00 C1 64 C4 66 B0 43 00 08 FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
But in the interfaces it's not showing:
Router#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES unset  administratively down down
GigabitEthernet0/0         unassigned      YES unset  administratively down down
GigabitEthernet0/1         unassigned      YES unset  administratively down down
Any idea what could be the problem?
I will like to mention that I tried it in both EHWIC slots of the router without any success.
7 Replies 7
I think you might need a T train release, such as 15.6.2T3. Can you give that a try ?
https://software.cisco.com/download/home/282977114/type/280805680/release/15.6.2T3
Hello, thank you for your reply. I loaded Version 15.4(2)T and no success.
While reloading the router I saw the following log message:
%ESWGE_ERR-3-PLL_LOCK_LOSS: EHWIC FPGA CORE PLL PLL Failed to LOCK  in 0/0/0 ehwic slot
I tried with the other EHWIC slot of the router and the same type of error is displayed:
%ESWGE_ERR-3-PLL_LOCK_LOSS: EHWIC FPGA CORE PLL PLL Failed to LOCK  in 0/1/0 ehwic slot
Should I consider the board as being broken?
it is either the card, or the (connectors inside) the router, but since the problem occurs in both slots, it is probably the card...
Do you have a warranty ?
No warranty. It's a second hand card that I bought for my CCNA home lab.
I suspect the card as being bad because I tried it in 2 other routers and the same issue appears. I tried to clean the EHWIC connectors and didn't help.
definitely sounds like a bad card. Can you go back to the seller ?
Hello, I've contacted them, now I'm waiting for their feedback. The purchase was made via ebay so I hope we can reach a solution together.
I can confirm that I have this problem too on C1921 running 15.8(3).M5 with a brand-new 4ESG-P:
My specific card is eHWIC-4ESG-P and note that my C1941 it is ALSO Hw Revision: 1.0 ... it is starting to feel there's something more to it than a bad card; my guess.
The other card installed, HWIC-4ESW works fine. Same behavior if I take out the 4ESW and leave only the 4ESG installed. Same story if I swap the card among slots or if I put 4ESG on the other slot leaving the other one empty. So, no matter what I do, the 4ESG it is not showing its interfaces but always appears on show inventory.
Please note the log first lines:
... %ESWGE_ERR-3-NIOSII_UP_FAIL: NIOSII fails on 0/0/0 ehwic slot
... %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x71
Following are all the details:
show inventory
NAME: "CISCO1921/K9", DESCR: "CISCO1921/K9 chassis, Hw Serial#: FTX1604853M, Hw Revision: 1.0"
PID: CISCO1921/K9 , VID: V04 , SN: FTX1604853M
NAME: "4 Port GE POE EHWIC Switch on Slot 0 SubSlot 0", DESCR: "4 Port GE POE EHWIC Switch"
PID: EHWIC-4ESG-P , VID: V01 , SN: FOC2041581E
NAME: "4 Port FE Switch on Slot 0 SubSlot 1", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 , SN: FOC12170QJN
show hardware
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.8(3)M5, RELEASE SOFTWARE (fc1)
Compiled Thu 13-Aug-20 04:14 by prod_rel_team
nimbus uptime is 34 minutes
System restarted at 23:26:28 UTC Thu Dec 23 2021
System image file is "usbflash0:/system/c1900-universalk9-mz.SPA.158-3.M5.bin"
export@cisco.com.
Processor board ID FTX1604853M
4 FastEthernet interfaces
1 terminal line
License Info:
License UDI:
Device# PID SN
*1 CISCO1921/K9 FTX1604853M
securityk9
datak9
data None None None
Configuration register is 0x3922
show version
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device# PID SN
securityk9
datak9
data None None None
show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level critical, 0 messages logged, xml disabled,
filtering disabled
Monitor logging: level critical, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 50 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: enabled
Persistent logging: disabled
No active filter modules.
Trap logging: disabled
Log Buffer (16384 bytes):
*Jan 2 00:00:02.479: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Jan 2 00:00:02.483: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jan 2 00:00:02.839: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan 2 00:00:03.063: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = securityk9 and License = securityk9
*Dec 23 23:26:40.171: %RBCP-7-SCP_SET_MSG: RBCP protocal on Interface Embedded-Service-Engine0/0,changed state to up
*Dec 23 23:26:51.879: %ESWGE_ERR-3-NIOSII_UP_FAIL: NIOSII fails on 0/0/0 ehwic slot
*Dec 23 23:26:52.435: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x71
show diag
Slot 0:
C1921 Mother board 2GE, integrated VPN and 2W Port adapter, 10 ports
Port adapter insertion time 00:35:46 ago
PCB Serial Number : FOC155113D3
Part Number : 73-12850-05
Top Assy. Part Number : 800-33408-03
Board Revision : A0
Fab Version : 02
Version Identifier : V04
CLEI Code : COMKK00DRD
Processor type : C8
Chassis Serial Number : FTX1604853M
Chassis MAC Address : 2894.0ff2.f760
0x00: 04 FF C1 8B 46 4F 43 31 35 35 31 31 33 44 33 40
0x10: 06 AC 41 01 00 82 49 32 32 05 C0 46 03 20 00 82
0x20: 80 03 42 41 30 88 00 00 00 00 02 02 CB 8C 43 49
0x30: 53 43 4F 31 39 32 31 2F 4B 39 89 56 30 34 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4F 4D 4B 4B 30 30 44 52
0x50: 44 09 C8 C2 8B 46 54 58 31 36 30 34 38 35 33 4D
0x60: C3 06 28 94 0F F2 F7 60 43 00 20 C4 08 00 00 00
WIC Slot 0:
4 Port GE Switch with POE
PCB Serial Number : FOC2041581E
Part Number : 74-7180-01
Board Revision : E0
Product (FRU) Number : EHWIC-4ESG-P
CLEI Code : COUIA47CAA
Base MAC Address : a0e0.aff7.2f50
0x00: 04 FF 40 06 B5 C1 8B 46 4F 43 32 30 34 31 35 38
0x10: 31 45 41 01 00 82 4A 1C 0C 01 42 45 30 88 00 00
0x20: 00 00 CB 8C 45 48 57 49 43 2D 34 45 53 47 2D 50
0x30: 89 56 30 31 20 D9 03 40 C1 CB C6 8A 43 4F 55 49
0x40: 41 34 37 43 41 41 CF 06 A0 E0 AF F7 2F 50 43 00
0x50: 08 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
4 Port FE Switch
Base MAC Address : 001f.9e61.4cf2
MAC Address block size : 4
PCB Serial Number : FOC12170QJN
Hardware Revision : 6.0
Part Number : 73-8474-06
Board Revision : A0
Top Assy. Part Number : 800-24193-02
Fab Version : 05
CLEI Code : IPUIA00RAA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-4ESW
Connector Type : 01
0x00: 04 FF CF 06 00 1F 9E 61 4C F2 43 00 04 C1 8B 46
0x10: 4F 43 31 32 31 37 30 51 4A 4E 40 00 56 41 06 00
0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
