08-06-2024 01:52 PM
Can anyone get SVI's to behave when using 64bit EIGRP metrics? I see this behavior on IOS-XE 16.9.5 and 17.9.5
What I mean by this is, if you have a L2 port-channel, with 2 x 40g members this will "lose" in EIGRP delay calculation to a single routed 10g port.
Setting the minimum delay (1) , or a max bandwidth the platform supports (in my case 200 Gigs) does not lower the picosecond delay below that of a 1 g link when looking at the topology table.
the show interface | include DLY command, shows the DLY that would be used in a 32bit EIGRP calculation, so is not helpful.
When using a L3 port-channel - With an IP address on the interface, the picosecond delay is calculated correctly.
Does anyone know
(1) of a way to manually set picosecond delay ?
(2) a show command that shows the 64bit picosecond delay of interfaces (outside of figuring it out from the topology table)
Nick
08-09-2024 07:42 AM
Thank you for the reply - this would work fine in the IDF situation, what is not shown in my diagram for simplicities sake is the many international links, with more than one hop that route via the Atlantic in some cases, not via the 9 foot fiber in the same room. I also do not want to confuse anyone with recursive next hops (which sometimes are still not the opposite core) - at least in EIGRP.
I think the bigger issue here is Cisco gives us the tools we need to make Wide metric EIGRP behave in Nexus, but not in IOS. The feature parity is not there. I think development has basically stopped on EIGRP, so I will hasten my efforts to move to OSPF/BGP. TAC is 99 percent sure there is no way to set delay less than the "one gig delay" in IOS. The workaround of Making 10g / 40g /100g links slower than a delay of 10 microseconds seems completely wrong. It breaks things downstream. The easier fix for now is just adding L3 port-channels.
As far is Nexus is concerned when entering picosecond delays on SVI's- the table in the white paper is what we are using.
5.5.1.2 Cisco Interface Delay Compatibility For compatibility with Cisco products, the following table shows the times in picoseconds EIGRP uses for bandwidth and delay Bandwidth Classic Wide Metrics Interface (Kbps) Delay Delay Type --------------------------------------------------------- 9 500000000 500000000 Tunnel 56 20000000 20000000 56Kb/s 64 20000000 20000000 DS0 1544 20000000 20000000 T1 2048 20000000 20000000 E1 10000 1000000 1000000 Ethernet 16000 630000 630000 TokRing16 45045 20000000 20000000 HSSI 100000 100000 100000 FDDI 100000 100000 100000 FastEthernet 155000 100000 100000 ATM 155Mb/s 1000000 10000 10000 GigaEthernet 2000000 10000 5000 2 Gig 5000000 10000 2000 5 Gig 10000000 10000 1000 10 Gig 20000000 10000 500 20 Gig 50000000 10000 200 50 Gig 100000000 10000 100 100 Gig 200000000 10000 50 200 Gig 500000000 10000 20 500 Gig
