EIGRP AD manipulation
noliveira
Hi all,
The below route for 192.168.2.0 is learned from two sources, one external eigrp and second internal eigrp with distance changed to 171.
When I clear the route with distance 171 the one learned from 10.0.0.2 with distance 170 takes over and stays in the routing table but if I flap the one learned from 10.0.0.2 with distance 170 it never takes over route with distance 171.
Any ideas why?
LNS5(config-router)#do sh ip route 192.168.2.0
Routing entry for 192.168.2.0/24
Known via "eigrp 115", distance 170, metric 53760
Tag 2755, type external
Redistributing via eigrp 115
Last update from 10.0.0.2 on FastEthernet1/0, 00:05:48 ago
Routing Descriptor Blocks:
* 10.0.0.2, from 10.0.0.2, 00:05:48 ago, via FastEthernet1/0
Route metric is 53760, traffic share count is 1
Total delay is 1100 microseconds, minimum bandwidth is 100000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 100/255, Hops 1
Route tag 2755
Known via "eigrp 115", distance 171, metric 293120, type internal
Last update from 172.16.0.1 on FastEthernet0/0, 00:04:19 ago
* 172.16.0.1, from 172.16.0.1, 00:04:19 ago, via FastEthernet0/0
Route metric is 293120, traffic share count is 1
Total delay is 5200 microseconds, minimum bandwidth is 16000 Kbit
Loading 1/255, Hops 2
Many thanks
Deepak Kumar
Can you share some more details as EIGRP configuration, EIGRP routers, topology details with us?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
@noliveira wrote:
Hi all,
It sounds like the route is "stuck in active"  when you failover with the flapping of the interface.
May I ask how long did you wait for convergence?  The SIA timer defaults to 3mins(180 seconds) If you had waited most probably you would have seen the primary route re-populated because the neighbor of the alternative route would reset.
When you failover again can you post the following command:
sh ip eigrp topology active
Kind Regards
Paul
on a side note, if your IOS supports it, try and configure the fast-reroute feature:
LNS5(config)#router eigrp LNS
LNS5(config-router)#address-family ipv4 unicast autonomous-system 115
LNS5(config-router-af)#topology base
LNS5(config-router-af-topology)#fast-reroute per-prefix all
