EIGRP Adjacency Problem
jgtheodor
I have two routers connected through a Frame-Relay cloud with point-to-point subinterfaces. There is a connection between those routers at Layers 1 & 2. Routers see each other from CDP and ping each other serial interfaces. However there is no any EIGRP Adjacency between them. The router with 12.4(9)T7 IOS do not send hello packets out of serial interface nor receive. Does anybody know if there is a known bug for that IOS version. I have checked the EIGRP Configuration and is correct. Frame-Relay confguration also is correct. I can see LMI packets at both sides.
3 Accepted Solutions
Giuseppe Larosa
I would try to issue the following:
router eigrp ASN
no passive-interface serialx/y
and see if anything changes
even if not needed you could add a frame-relay map ip x.x.x.x with broadcast option under point-to-point FR subif
or simply a clear ip eigrp ASN to rerun the process may be eigrp process was created before configuring the ip address on the serial interface.
Hope to help
Giuseppe
Edison Ortiz
Have you tried using the neighbor command under the EIGRP process and see if unicast work within EIGRP?
By default, EIGRP will use multicast for the exchange of hello packets.
Point-to-Point subinterfaces should provide the multicast service by default, thus I'm not sure why it isn't working.
Can you provide configs along with the show frame pvc output?
__
Edison.
Kevin Dorrell
Level 10
Level 10
Could you post the configs please? Maybe it is simply a typo. Sometimes it takes two sets of eyes to spot them.
If you do show ip protocols, do you see EIGRP on the interface?
5 Replies 5
Giuseppe Larosa
router eigrp ASN
Hope to help
Giuseppe
Edison Ortiz
__
Edison.
Kevin Dorrell
Level 10
Level 10
You are right...I think I am little stupid..I was using the follow set of commands ander EIGRP :
passive-interface default
no passive-interface Serial0/0/0
no passive-interface BRI0/1/0
So i added th command
no passive-interface Serial0/0/0.100 and it seems working fine..
steveo123
have you tried disabling spilt horizon for EIGRP on the hub router..?
steve Knockswell
