EIGRP and a default route
amarula115
Hi. I have 19 sites in my WAN. I run EIGRP on my network. I am distributing default route 0.0.0.0 to all the sites since they don't have local internet access and they come to central site for internet. Right now I will be connecting site #20 to my WAN and this site will have local internet access so I don't want to distribute default route to this particular site through EIGRP. How can I stop distributing default route to this one site only? Should I filter this route while it is getting to the router at site #20 ? If yes, how to do it? Access list? I would appreciate your help
aneesh.ts
Use Access-list with distribute-list for the same.
access-list 101 deny 0.0.0.0 0.0.0.0
access-list 101 permit any any
router eigrp
distribute list 101 in
I think you may also use a standard acl
access-list 1 deny 0.0.0.0
access-list 1 permit any
router eigrp
distribute list 1 in
Hello Aneesh,
If ACLs are used in distribute lists, they verify (i.e. filter upon) the following attributes of filtered routes:
A standard ACL checks only the network's address. It does not verify its netmask or any other attribute.
An extended ACL checks both the next hop and the network's address. The next hop is verified against the source part of an ACL entry, the network's address is verified against the destination part. Again, the network mask is not verified. Note that this fact requires rewriting your ACL 101:
access-list 101 deny ip any host 0.0.0.0
access-list 101 permit ip any any
If an extended ACL is used in the outbound direction, the next-hop address provided as an input to the ACL will always be 0.0.0.0.
If a precise control over advertised networks and netmasks is necessary in distribute lists, it is recommended to use prefix lists.
Best regards,
Peter
wszhangxuan
I would leave the EIGRP default route there and add one static route on the site.
"ip route 0.0.0.0 0.0.0.0 Interface XX"
The static route will take over EIGRP and if the Outgoing interface goes down, EIGRP will kick in :)
Thank you to all of you guys. I think using static default route on the site router is the best solution since it will give some redundancy. If local internet at site #20 fails than traffic will be sent out to internet through central site using EIGRP default route. Thanks again
