01-12-2013 09:02 PM - edited 03-04-2019 06:41 PM
Friends,
Topology:
Remote site
MPLS Service Provider
Router A----------Router B
Existing model:
Router A and B peers with MPLS service Provider via eBGP..Both local AS numbers and remote AS numbers are same. The service provider does AS over ride
Router A and B peers via P2P link through EIGRP.. (conenct through serial interfaces)
Traffic from site A to Site B and vice versa is via P2P Link.
We use some eigrp distance tweaking on remote site A and B so that eigrp learnt routes are preferred over EBGP routes.
What is required?
Let's say router A's MPLS is tear down, the traffic path
1) From site A to B, is already via P2P (the primary link)
2) From Site A to any remote sites should also route via P2P. This is the requirement.
Similarly, when Router B's MPLS is dow, the other way round should also work.
Few Questions :
1. Is it good to peer Router A and Router B via iBGP?
- I will use network command to advertise all prefixes at both ends- ruouter A and router B.
Now, rouer A and Router B will both hase an IGP matching route in the routing table and then advertised via network command. will both advertise into the cloud ?
- May be I can use path atribute like a prepend to influence the router
- Earlier we has issues when advertising the same prefix from two location (thread 3728134) Should I use community attribute to distinguish the routes?
- What are other things I should take into consideration?
- Do you see any design docs for this?
2. Use simple EIGRP to BGP with mutual redistribution at two points -A and B ?
3. Use policy based routing setting next hop for both Router A and B's traffic at LAN interface and then use to static to bgp redistribution with route tracking of remote sites?
01-13-2013 12:22 AM
Hi vinayaka,
Yes you can run IBGP between both routers and you can influence outgoing path through Router A setting high weight on Router A..
Also if you want to influence incoming path you can send AS-path attribute or MED.
Yes this is another solution ,you can do mutual redsitribution.
Here you have to change AD for routes you want to directly from router A to Router B(without crossing provider)
Polcy based routing is little complicated.
Praveen
