EIGRP BGP REDISTRIBUTION ISSUE
jagacms
Hi All,
i have a doubt what will happen under such scenario.. pls refer the R1 configs and topology diagram..
SCENARIO 1:
LOOPBACK > Advertised into Eigrp 123 via network 128.166.0.0 > REDISTRIBUTED INTO BGP 123 > ADV SUMMARY via aggregate-address 128.166.128.0 255.255.224.0 summary-only
in the above scenario under any circumstance the summary will be advertised as loopback will be up even though the all the downlinks F0/0 are down..
SCENARIO 2:
LOOPBACK > Redistribute connected in EIGRP 123 network 128.166.130.177 0.0.0.0  no auto-summary > REDISTRIBUTED INTO BGP 123 > ADV SUMMARY via aggregate-address 128.166.128.0 255.255.224.0 summary-only
Now i cant see the loopback subnet in the bgp table ????????
SCENRIO 3:
STATIC ROUTE  to reach a 128.166 subnet > Redistribute static in EIGRP 123 > REDISTRIBUTED INTO BGP 123 > ADV SUMMARY via aggregate-address 128.166.128.0 255.255.224.0 summary-only
what will happen now, wil the route still got advertised if the static next hop ip goes down ????????????
ROUTER CONFIG
R1
interface Loopback0
  ip address 128.166.130.246 255.255.255.255
interface FastEthernet0/0
ip address 128.166.130.177 255.255.255.248
interface Serial1/0
ip address 192.124.75.53 255.255.255.252
router eigrp 123
network 128.166.0.0
auto-summary
router bgp 123
bgp log-neighbor-changes
neighbor 192.124.75.54 remote-as 1
redistribute eigrp 123
network 192.124.75.52 mask 255.255.255.252
Fabrizio Pedracini
scenario 2 and 3 cannot work as you expect. When you redistribute EIGRP into BGP you actually redistibute the EIGRP routes which are in the routing table plus the subnets that are included in the "network" commands under EIGRP. Scenario 1 works because you used "network 128.166.0.0" under EIGRP.
When you do "redistribute connected/static" under EIGRP and then redistribute EIGRP into BGP, the connected/static routes are not redistributed into BGP.
hope this helps,
Fabrizio
