EIGRP / DMVPN - EIGRP fails to establish neighborship - CCNP lab
MikeAW2010
So I am having problems getting EIGRP to establish neighborship for a CCNP based lab. I have the WAN side configured for eBGP and also have a static default route pointing at the cloud (which is actually a router running eBGP.) but EIGRP fails to establish neighborship. I pasted all the configs, can anyone tell me what I'm doing wrong? I kind of feel that the Cloud (since its a router) needs to tunnel network added to the BGP table but what doesn't make sense is how does DMVPN work in the real world with real ISP's without advertising someone's corporate VPN Tunnel network?
CLOUD (Router running eBGP)
Building configuration...
Current configuration : 1673 bytes
version 15.5
hostname Cloud
boot-start-marker
boot-end-marker
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone CST -6 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Ethernet0/0
 ip address 172.16.11.2 255.255.255.252
interface Ethernet0/1
 no ip address
 shutdown
interface Ethernet0/2
 no ip address
 shutdown
interface Ethernet0/3
 no ip address
 shutdown
interface Ethernet1/0
 ip address 172.16.31.2 255.255.255.252
interface Ethernet1/1
 no ip address
 shutdown
interface Ethernet1/2
 no ip address
 shutdown
interface Ethernet1/3
 no ip address
 shutdown
interface Ethernet2/0
 ip address 172.16.41.2 255.255.255.252
interface Ethernet2/1
 no ip address
 shutdown
interface Ethernet2/2
 no ip address
 shutdown
interface Ethernet2/3
 no ip address
 shutdown
router bgp 100
 bgp log-neighbor-changes
 network 172.16.11.0 mask 255.255.255.252
 network 172.16.31.0 mask 255.255.255.252
 network 172.16.41.0 mask 255.255.255.252
 neighbor 172.16.11.1 remote-as 11
 neighbor 172.16.31.1 remote-as 31
 neighbor 172.16.41.1 remote-as 41
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input none
end
R11
Current configuration : 1397 bytes
version 15.5
hostname R11
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
 ip address 10.1.1.1 255.255.255.0
interface Tunnel100
 bandwidth 4000
 ip address 192.168.100.11 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip split-horizon eigrp 100
 ip nhrp map multicast dynamic
 ip tcp adjust-mss 1360
 tunnel source Ethernet0/0
 tunnel mode gre multipoint
 tunnel key 100
 ip address 172.16.11.1 255.255.255.252
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router eigrp 100
 network 10.0.0.0
 network 192.168.100.0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.11.2
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
R31
Current configuration : 1449 bytes
version 15.5
hostname R31
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
 ip address 10.3.3.1 255.255.255.0
interface Tunnel100
 bandwidth 4000
 ip address 192.168.100.31 255.255.255.0
 ip mtu 1400
 ip nhrp map multicast 172.16.11.1
 ip nhrp map 192.168.100.11 172.16.11.1
 ip nhrp network-id 100
 ip nhrp nhs 192.168.100.31
 tunnel destination 172.16.11.1
 tunnel key 100
 ip address 172.16.31.1 255.255.255.252
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router eigrp 100
 network 10.0.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.31.2
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
R41
version 15.5
hostname R41
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
 ip address 10.4.4.1 255.255.255.0
interface Tunnel100
 bandwidth 4000
 ip address 192.168.100.41 255.255.255.0
 ip mtu 1400
 ip nhrp nhs 192.168.100.11
 tunnel key 100
 ip address 172.16.41.1 255.255.255.252
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router eigrp 100
 network 10.0.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.41.2
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
I rebuilt your topology and found a number of crucial things, the most important being the no BGP at all is configured on any of the DMVPN routers. There was also a missing network ID on R11.
Make sure the configs look exactly like below (important parts marked in bold
Cloud
version 15.5
hostname Cloud
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R11
version 15.5
hostname R11
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 100
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 11
neighbor 172.16.11.2 remote-as 100
router eigrp 100
network 10.1.1.0 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R31
version 15.5
hostname R31
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 31
neighbor 172.16.31.2 remote-as 100
router eigrp 100
network 10.3.3.1 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R41
version 15.5
hostname R41
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 41
neighbor 172.16.41.2 remote-as 100
router eigrp 100
network 10.4.4.1 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
5 Replies 5
ngkin2010
Level 7
Level 7
1. First to verify the DMVPN is correctly formed or not, according to the given configuration. The 'network-id' is incorrect on DMVPN's Hub:
interface Tunnel100
  ip nhrp network-id 100  <Missing command>
2. After fixing the DMVPN, verify the status by 'show dmvpn'
# show dmvpn
 # Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb
     1 172.16.31.1      192.168.100.31    UP 00:00:13     D
     1 172.16.41.1      192.168.100.41    UP 00:00:32     D
3. Then, verify the tunnel is UP by pinging to DMVPN hub
ping 192.168.100.11 source tunnel100
4. then verify the EIGRP status over the DMVPN tunnel by 'show ip eigrp neighbor'
5. Finally verify the EIGRP by pinging to DMVPN Spoke from Spoke
ping 192.168.100.31 source tunnel100
ping 192.168.100.41 source tunnel100
6. Verify the NHS on DMVPN hub by 'show ip nhrp'
192.168.100.11/32
Tunnel100 created 00:02:28, expire 00:00:36
Type: incomplete, Flags: negative
Cache hits: 2
192.168.100.31/32 via 192.168.100.31
Tunnel100 created 00:04:44, expire 01:55:37
Type: dynamic, Flags: unique registered used nhop
NBMA address: 172.16.31.1
192.168.100.41/32 via 192.168.100.41
Tunnel100 created 00:04:42, expire 01:55:19
NBMA address: 172.16.41.1
7. Verify trace route to see if DMVPN is working as expected (phase 1 DMVPN; traffic first sent to hub)
traceroute 192.168.100.31 source 192.168.100.41
Tracing the route to 192.168.100.31
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.100.11 1 msec 0 msec 0 msec
  2 192.168.100.31 1 msec 1 msec 0 msec
Therefore, resolving the 'network-id' on DMVPN hub should help you to solve the problem.
But the BGP (underlay network) configuration was not correctly configured, you currently rely on static default route to form the DMVPN tunnel.
Regarding to your last question below:
The cloud (or the ISP) as a underlay network only need to advertise (& route) the traffic between physical interfaces (e.g. e0/0 in our lab). All Corp's traffic leaving the DMVPN tunnel will be encapsulated by additional IP header (with the source IP address of e0/0). Therefore, in the view of ISP, they see the Corp's traffic is sourcing from 172.16.41.1 to 172.16.11.1.  After the packet has routed to remote router, router will decapsulate the packet accordingly.
BGP is just the underlying WAN protocol, as long as all your neighbors are up, that is, as long as WAN connectivity is established, you don't need to advertise any other networks.
With regard to your (phase 2) DMVPN, make the changes/additions marked in bold:
R11
version 15.5
hostname R11
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
no ip redirects
ip mtu 1400
--> no ip next-hop-self eigrp 100
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router eigrp 100
--> network 10.1.1.1 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R31
version 15.5
hostname R31
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
--> tunnel mode gre multipoint
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router eigrp 100
--> network 10.3.3.1 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R41
version 15.5
hostname R41
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router eigrp 100
--> network 10.4.4.1 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
tunnel mode multipoint need on all Spoke Router,
you don't config the tunnel destination in PhaseII of DMVPN.
all other config is OK. no need to change
Cloud
version 15.5
hostname Cloud
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R11
version 15.5
hostname R11
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
no ip redirects
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 11
router eigrp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R31
version 15.5
hostname R31
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 31
router eigrp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R41
version 15.5
hostname R41
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel100
bandwidth 4000
ip mtu 1400
tunnel key 100
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
router bgp 41
router eigrp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
It was the missing BGP configs on the spokes. I didn't notice that wasn't configured.
R31 came up immediately.
R41 oddly took several minutes before it came up but it eventually did.
