EIGRP - feasable sucessor route same AD as FD ?
dtushing123
Level 3
Level 3
Do feasable sucessor routes have to have a lower advertised distance than the sucessor routes feasable distance or can it be the same ?
Router# show ip eigrp topology
IP-EIGRP Topology Table for process 77
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - Reply status
P 172.16.90.0 255.255.255.0, 2 successors, FD is 0
via 172.16.80.28 (46251776/46226176), Ethernet0
via 172.16.81.28 (46251776/46226176), Ethernet1
via 172.16.80.31 (46277376/46251776), Serial0
P 172.16.81.0 255.255.255.0, 1 successors, FD is 307200
via Connected, Ethernet1
via 172.16.81.28 (307200/281600), Ethernet1
via 172.16.80.28 (307200/281600), Ethernet0
via 172.16.80.31 (332800/307200), Serial0
If so would the following routes ever become sucessors ?
For 172.16.90.0 255.255.255.0
For 172.16.81.0 255.255.255.0
D
mheusinger
Level 10
Level 10
it has to be lower. If it is equal, then the router is no FS.
You did not obtain a digital copy of the ICND materials, did you?
Regards, Martin
Thanks Martin, I do have the ICND materials from when I did the CCNA, I got the Ciscopress book with the CD. Actually for this example I cut and pasted from the Cisco docs on show ip eigrp topo.
I'm trying to pass the BSCI at the moment and wanted to clarify that EIGRP issue.
Having some problems with the wording of the BSCI. Sometimes can't tell exactly what they're asking...
Anyway going to try again tommorow.
Good luck with the BSCI!
Just one note: the BSCI has been updated and a new exam is out reflecting the new content. Make sure you take the exam matching your study material.
BSCI:
http://www.cisco.com/web/learning/le3/le2/le37/le10/learning_certification_type_home.html
Regards, Martin
