Eigrp flapping on DMVPN tunnel.
asmlicense
Hi to all!
We have this problem for about 1 or 2 month.
It's flapping almost everytime, but not on all spokes. We have on HUB in HQ connected over MPLS vlan to other spokes. Here is config of HUB router:
___________________________________________________
vrf definition IWAN-PUBLIC-ASM
 description IWAN ASM
 address-family ipv4
 exit-address-family
key chain LAN-KEY
 key 1
   key-string *****
crypto ikev2 keyring DMVPN_CRY_ASM
 peer ANY
  address 0.0.0.0 0.0.0.0
  pre-shared-key *****
crypto ikev2 profile DMVPN_IKEVPR_ASM
 match fvrf IWAN-PUBLIC-ASM
 match identity remote address 0.0.0.0
 authentication remote pre-share
 authentication local pre-share
 keyring local DMVPN_CRY_ASM
crypto ipsec transform-set AES256/SHA/TRANSPORT esp-aes 256 esp-sha-hmac
 mode transport
crypto ipsec profile DMVPN_CRYPR_ASM
 set transform-set AES256/SHA/TRANSPORT
 set ikev2-profile DMVPN_IKEVPR_ASM
interface Tunnel10
 bandwidth 200000
 ip address 192.168.0.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp authentication *****
 ip nhrp map multicast dynamic
 ip nhrp network-id 101
 ip nhrp holdtime 600
 ip nhrp redirect
 ip tcp adjust-mss 1360
 delay 100
 tunnel source GigabitEthernet0/0/3.1000
 tunnel mode gre multipoint
 tunnel key 101
 tunnel path-mtu-discovery
 tunnel vrf IWAN-PUBLIC-ASM
 tunnel protection ipsec profile DMVPN_CRYPR_ASM
interface GigabitEthernet0/0/3.1000
 description TO_BRANCHES
 encapsulation dot1Q 3029
 vrf forwarding IWAN-PUBLIC-ASM
 ip address 192.168.255.1 255.255.255.0
router eigrp IWAN-EIGRP
 address-family ipv4 unicast autonomous-system 300
  af-interface default
   passive-interface
  exit-af-interface
  af-interface Tunnel10
   authentication mode md5
   authentication key-chain LAN-KEY
   hello-interval 20
   hold-time 60
   no passive-interface
   no split-horizon
  exit-af-interface
  topology base
   redistribute ospf 10 metric 10000 10 255 1 10000
  exit-af-topology
  network 192.168.0.1 0.0.0.0
  nsf
 exit-address-family
router ospf 10
 router-id 172.16.0.10
 redistribute eigrp 300 subnets
 network 172.16.0.10 0.0.0.0 area 0
ip route vrf IWAN-PUBLIC-ASM 0.0.0.0 0.0.0.0 192.168.255.3
and that is config of Spoke router:
vrf definition IWAN-TRANSPORT-2
 description IWAN-TRANSPORT-2
 address-family ipv4
 exit-address-family
key chain LAN-KEY
 key 1
   key-string *****
crypto ikev2 proposal IK2-Proposal
 encryption aes-cbc-128
 integrity sha1 md5
 group 2 5
crypto ikev2 policy IK2-Policy
 match fvrf IWAN-TRANSPORT-2
 match address local 192.168.255.25
 peer ANY
 mode transport
interface Tunnel1
 bandwidth 100000
 ip address 192.168.0.11 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp nhs 19.168.0.1 nbma 192.168.255.1 multicast
 ip nhrp registration no-unique
 ip nhrp shortcut
 delay 10
 if-state nhrp
 tunnel source GigabitEthernet0/0/0.1000
 tunnel key 101
 tunnel vrf IWAN-TRANSPORT-2
interface GigabitEthernet0/0/0.1000
 vrf forwarding IWAN-TRANSPORT-2
 ip address 192.168.255.11 255.255.255.0
 no ip proxy-arp
 no cdp enable
   passive-interface
  exit-af-interface
   hello-interval 20
   hold-time 60
   no split-horizon
  exit-af-interface
  topology base
  exit-af-topology
  network 192.168.0.11 0.0.0.0
 exit-address-family
ip route vrf IWAN-TRANSPORT-2 0.0.0.0 0.0.0.0 192.168.255.1
_____________________________________________________
We have such kind of problem, I'll share logs with you too:
on HUB:
Sep  9 11:59:30.683: EIGRP: Build goodbye tlv for 192.168.0.12
Sep  9 12:01:28.759: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.7 (Tunnel10) is down: holding time expired
Sep  9 12:01:28.762: EIGRP: Build goodbye tlv for 192.168.0.7
Sep  9 12:02:25.448: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: peer restarted
Sep  9 12:02:45.465: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:03:07.661: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.6 (Tunnel10) is down: holding time expired
Sep  9 12:03:07.665: EIGRP: Build goodbye tlv for 192.168.0.6
Sep  9 12:03:45.559: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: holding time expired
Sep  9 12:03:45.563: EIGRP: Build goodbye tlv for 192.168.0.11
Sep  9 12:03:52.299: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:04:02.124: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.7 (Tunnel10) is up: new adjacency
Sep  9 12:04:39.693: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.12 (Tunnel10) is up: new adjacency
Sep  9 12:04:52.303: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: holding time expired
Sep  9 12:04:52.305: EIGRP: Build goodbye tlv for 192.168.0.11
Sep  9 12:05:45.414: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:06:07.439: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: peer restarted
Sep  9 12:06:45.175: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:08:42.221: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.6 (Tunnel10) is up: new adjacency
Sep  9 12:08:42.228: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.12 (Tunnel10) is down: peer restarted
Sep  9 12:10:16.217: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.12 (Tunnel10) is up: new adjacency
Sep  9 12:13:13.533: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.14 (Tunnel10) is down: holding time expired
Sep  9 12:13:13.536: EIGRP: Build goodbye tlv for 192.168.0.14
Sep  9 12:14:33.560: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.12 (Tunnel10) is down: holding time expired
Sep  9 12:14:33.563: EIGRP: Build goodbye tlv for 192.168.0.12
Sep  9 12:14:33.568: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.7 (Tunnel10) is down: peer restarted
Sep  9 12:14:43.100: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: holding time expired
Sep  9 12:14:43.107: EIGRP: Build goodbye tlv for 192.168.0.11
Sep  9 12:14:52.276: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.7 (Tunnel10) is up: new adjacency
Sep  9 12:15:06.627: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.14 (Tunnel10) is up: new adjacency
Sep  9 12:15:26.654: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:15:48.672: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is down: peer restarted
Sep  9 12:16:08.234: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.11 (Tunnel10) is up: new adjacency
Sep  9 12:16:25.445: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.12 (Tunnel10) is up: new adjacency
Sep  9 12:16:28.686: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.6 (Tunnel10) is down: holding time expired
Sep  9 12:16:28.690: EIGRP: Build goodbye tlv for 192.168.0.6
on SPOKE:
.Sep  9 12:32:14.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.Sep  9 12:32:21.893: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is up: new adjacency
.Sep  9 12:32:24.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.Sep  9 12:32:24.148: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is down: interface down
.Sep  9 12:32:34.172: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.Sep  9 12:32:41.909: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is up: new adjacency
.Sep  9 12:32:44.173: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.Sep  9 12:32:44.175: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is down: interface down
.Sep  9 12:56:54.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.Sep  9 12:56:54.516: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is up: new adjacency
.Sep  9 12:57:04.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.Sep  9 12:57:04.184: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is down: interface down
.Sep  9 12:57:14.209: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.Sep  9 12:57:14.534: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is up: new adjacency
.Sep  9 13:00:44.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.Sep  9 13:00:44.214: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is down: interface down
.Sep  9 13:10:14.218: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
.Sep  9 13:10:14.290: %DUAL-5-NBRCHANGE: EIGRP-IPv4 300: Neighbor 192.168.0.1 (Tunnel1) is up: new adjacency
Maybe anybody has seen this problem? We have researched almost everywhere, even in this forum, but haven't found good solution.
asmlicense
I changed MTU and TCP adjust on HUB side and it helped a little.
I continues to flap, but not on all spokes now. Only on 2-3 of them.
I set:
ip mtu 1300
ip tcp adjust-mss 1260
Do you have any suggestions?
I just experienced this today on my IWAN deployment. 3/4 of my sites went down (at the same time), NHRP was working fine, but EIGRP was flapping. However, a router reboot at spoke resolved the issue, as soon as I rebooted, the site came up fine. My MTU is set to 1400 (the default).
Have you had the issue again in the last month?
