Eigrp Flexvpn
sblackman68
I’m looking for some help on an EIGRP issue we’re having with route advertisements over a FlexVPN between two sites. The spoke router is receiving a full routing table from the hub and this is being redistributed down to the L3 Switch but the hub is not installing routes from the spoke router into it’s topology or routing tables. The spoke router is receiving routes from the L3 switch and these appear in the topology table for AS 203 but the hub router is seeing these with infinite metrics:
480  12:47:13.926 Update reason, delay: new if delay(Infinity)
481  12:47:13.926 Update sent, RD: 10.103.34.0/24 metric(Infinity)
482  12:47:13.926 Update reason, delay: metric chg delay(Infinity)
483  12:47:13.926 Update sent, RD: 10.103.34.0/24 metric(Infinity)
484  12:47:13.926 Route installed: 10.103.34.0/24 10.199.104.251
485  12:47:13.926 Route installing: 10.103.34.0/24 10.199.104.251
486  12:47:13.926 Find FS: 10.103.34.0/24 metric(Infinity)
487  12:47:13.926 Rcv update met/succmet: metric(9831710720) metric(1966080)
488  12:47:13.926 Rcv update dest/nh: 10.103.34.0/24 10.199.104.251
489  12:47:13.926 Metric set: 10.103.34.0/24 metric(Infinity)
490  12:47:13.926 Metric set: 10.103.30.0/29 metric(9831710720)
491  12:47:13.926 Update reason, delay: new if delay(Infinity)
492  12:47:13.926 Update sent, RD: 10.103.30.0/29 metric(Infinity)
493  12:47:13.926 Update reason, delay: metric chg delay(Infinity)
494  12:47:13.926 Update sent, RD: 10.103.30.0/29 metric(Infinity)
495  12:47:13.926 Route installed: 10.103.30.0/29 10.199.104.251
496  12:47:13.926 Route installing: 10.103.30.0/29 10.199.104.251
497  12:47:13.926 Find FS: 10.103.30.0/29 metric(Infinity)
498  12:47:13.926 Rcv update met/succmet: metric(9831710720) metric(1966080)
499  12:47:13.926 Rcv update dest/nh: 10.103.30.0/29 10.199.104.251
500  12:47:13.926 Metric set: 10.103.30.0/29 metric(Infinity)
This is the topology I am using:
<![if !vml]><![endif]>
11 Replies 11
Deepak Kumar
Have you disabled split-horizon EIGRP on FlexVPN? Run a command on FlexVPN "no ip split-horizon eigrp <AS Number>.
Distance vector routing protocols like RIP and EIGRP rely on a number of measures for loop avoidance. One of these is split horizon, which prevents a route from being readvertised out the interface on which it was received.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hey, Many thanks.  Is this a default thing?  I will check config now???
Cheers,
Scott.
Under the VTI interface. Share your configuration.
Deepak Kumar
Deepak Kumar,
Not sure, which bit you mean??
Scott.
interface Tunnel1
ip unnumbered Loopback1
ip mtu 1400
ip nhrp network-id 4
ip nhrp shortcut virtual-template 1
ip nhrp redirect
zone-member security Tunnel
ip tcp adjust-mss 1360
tunnel source Dialer1
tunnel destination dynamic
tunnel protection ipsec profile FLEXVPN-IPSEC-PROFILE
interface GigabitEthernet0/0/0
description *** LAN ***
ip address 10.103.30.10 255.255.255.252
zone-member security Inside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface ATM0/1/0.1 point-to-point
description *** Connection to Internet ***
ip mtu 1458
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
Disable Split-Horizon as:
interface Virtual-Template1 type tunnel
Deepak Kumar
Deepak Kumar,
Scott.
interface Loopback1
ip address 10.199.104.251 255.255.255.255
interface Tunnel1
ip mtu 1400
ip nhrp redirect
Your diagram is not displayed at all, so I am unsure of your complete topology. However the configuration above has a sVTI which is referencing a Virtual-Template, so I assume this is a Hub-and-Spoke with Spoke-to-Spoke topology? - and this configuration is from a Spoke?
You would potentially need to disable split horizon on the Virtual Template on the HUB.
You should also ensure that the spokes only recieve routes from the HUB, so therefore configure passive-interface for all interfaces except the tunnel towards the HUB.
Hi, Apologies, diagram and config below, appreciate your help!!!
Scott.
interface Loopback1
interface Tunnel1
ip mtu 1400
ip nhrp redirect
negotiation auto
no ip address
shutdown
negotiation auto
interface ATM0/1/0
no ip address
ip mtu 1458
pvc 0/38
interface Ethernet0/1/0
no ip address
no negotiation auto
ip virtual-reassembly
interface Ethernet0/1/0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
vrf forwarding Mgmt-intf
ip address 192.168.0.1 255.255.255.0
negotiation auto
ip nhrp redirect
Re-reading the original post and looking at the diagram it doesn't seem like the routes are actually being readvertised out of the same interface they were received, correct?
Does the Hub install the Loopback interface IP address of the spoke in it's routing table?
Is this diagram complete? or are there other devices connected?
Morning,
Hi, I will find out more info.
Cheers,
Scott.
