EIGRP issue using VRF on 3850
jmperlewitz
Hello all,
We have a 4451 router which runs an integrated zone-based firewall.  We connect 2 physical interfaces via Port-channel to our core switch (3850).  We run a separate VRF for each zone on the switch so that is has it's own routing table.  We currently are using OSPF for our IGP with success.
However, I would like to setup EIGRP routing as well but I am having difficulty getting the VRF vlans to establish a neighbor relationship.  I can get the vlan that is not associated with any VRF to establish a neighbor relationship fine.  See my relevant info below:
4440:
Port-channel2          unassigned
Port-channel2.101      10.10.101.1
Port-channel2.103      10.10.103.1
Port-channel2.105      10.10.105.1
Port-channel2.107      10.10.107.1
Port-channel2.109      10.10.109.1
Port-channel2.111      10.10.111.1
3850:
Vlan101                10.10.101.2
Vlan103                10.10.103.2
Vlan105                10.10.105.2
Vlan107                10.10.107.2
Vlan109                10.10.109.2
Vlan111                10.10.111.2
VRFs:
  Name                           Default RD           Protocols     Interfaces
  109                              <not set>             ipv4,ipv6      Vl109
  105                              <not set>             ipv4,ipv6      Vl105
  Mgmt-vrf                         <not set>             ipv4,ipv6      Gi0/0
  111                              <not set>             ipv4,ipv6      Vl111
  103                              <not set>             ipv4,ipv6      Vl103
  107                              <not set>             ipv4,ipv6      Vl107
Vlan interfaces:
interface Vlan101
 description Internal_Infra
interface Vlan103
 description xxx_Infra
 vrf forwarding 103
interface Vlan105
 vrf forwarding 105
interface Vlan107
 vrf forwarding 107
interface Vlan109
 vrf forwarding 109
interface Vlan111
 vrf forwarding 111
OSPF reference:
We create separate OSPF processes for each vrf and it works fine
4451:
router ospf 65000
router-id 99.0.0.2
passive-interface default
no passive-interface Port-channel2.101
no passive-interface Port-channel2.103
no passive-interface Port-channel2.105
no passive-interface Port-channel2.107
no passive-interface Port-channel2.109
network 10.10.101.0 0.0.0.3 area 0
network 10.10.103.0 0.0.0.3 area 0
network 10.10.105.0 0.0.0.3 area 0
network 10.10.107.0 0.0.0.3 area 0
network 10.10.109.0 0.0.0.3 area 0
network 10.10.111.0 0.0.0.3 area 0
3850:
router ospf 109 vrf 109 router-id x.0.0.8 passive-interface default no passive-interface Vlan109
router ospf 65000
router-id x.0.0.3
no passive-interface Vlan101
EIGRP config so far:
4450:
router eigrp 65499
 default-metric 1000 100 255 1 1500
 redistribute bgp 65499 route-map BGP->EIGRP
router eigrp 104
 no passive-interface Port-channel2.103!
3850:
router eigrp 65499
router eigrp 104
address-family ipv4 vrf POS autonomous-system 104
no passive-interface Vlan103
exit-address-family
Any suggestions?
Deepak Kumar
Can you check VRF Name assigned in the switch is correct?
router eigrp 104
exit-address-family
But your VRF configuration is showing some other name:
  and Share the Switch configuration and check that zone-based firewall is not blocking eigrp.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
