Eigrp - metric tweak- vpls vs ipwan
stharmal
we have 2 wan providers. One is ip wan the other one is vpls...
each site has 2 wan routers.. One connected to vpls provider and the other to ip wan provider.
currently our preferred primary wan is vpls for all the sites...
i like to change the primary wan on one site to ip wan..
i tried teaking the metric by delay commabd .. That helped the outgoing traffic via the ip wan but the incoming is still via the vpls as the other sites consider this vpls as directly connected... Running show cdp Nei on a vpls wan router will show all the vpls routers in all site.
is there any way I can teak the incoming traffic also useds ip wan cct?
What routing protocol you are using on:
  • in-between all site routers over VPLS
  • in-between site router to IP WAN
Hi Vivek
We use EIgrp between sites a d within site.
